Results 1 to 4 of 4
Thread: power inverter
    Nov 2004
    power inverter
    i have a hp e-pc computer and a datalux screen (10.4") and i wanted to know which power inverter would do best, like how many watts would it have to be. i already have a 400 watt inverter/ 800 watt peak, would that be enough? Could someone help me out. I'm going out of town and i would really like to use it on my trip.
    that should be plenty. Most PCs have 250-300 watt power supply, so that inverter should be just right.
    KyferEz - Power Controllers (SDC), Inverters, Tank Circuit, GPS, OBDII, CarPCs, and more!
    PSU Wattage Calculator
    Electronics Calculators
    Copper Wire Data
    Maximum Bitrate dodgetimes2's Avatar
    The e-pc's only have a ~150Watt power supply. You should have plenty of extra power.
    1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    The rating needs to be for continous use.... the peak rating on the inverter is generally what is 'advertised'. Check the specs.
    Read the FAQ!
  1. Replies: 5
    Last Post: 02-04-2005, 11:07 AM
  2. Power Inverter Wiring with on/off switch.
    By lightningknight in forum Power Supplies
    Last Post: 01-23-2005, 02:33 AM
  3. FS: VECTOR MAXX 700 Power Inverter
    By muldrick in forum Classified Archive
    Last Post: 10-23-2004, 09:41 PM
  4. power inverter ruined ABS?
    By Parsec in forum Power Supplies
    Last Post: 08-11-2003, 08:08 AM
  5. UPS power backup as inverter?
    By CA 3000GT in forum Power Supplies
    Last Post: 02-13-2003, 02:52 PM
