Results 1 to 3 of 3
Thread: Antec Aria Case / Which power supply?
    Nov 2004
    I purchased the antec aria case(seen in the link below). I was wondering how should I power this unit? Should I use the default power supply, should I purchase a second battery and use the default power supply, or should I purchase another PS. I have a great deal of knowledge regarding building computers but I just need assistance on powering this thing.
    http://www.silentpcreview.com/article146-page1.html
    Constant Bitrate pirate_king00's Avatar
    Jan 2005
    It all depends on what your going to put into the box. If you use default powersupply than your going to need to use an inverter (which would be cheaper, but others say it creates noise).
    You could go to http://carpc.kyferez.com/ and under tools use the power supply calculator. This will tell you if you can get an opus 150 or if you will need to use a couple of dc to dc power supply's. I am useing the same case for my 2nd system that will be going in my 1996 Baja Outlaw.
    Oh by the way, newegg.com has that case for about 20 bucks cheaper.
    Nov 2004
    Thanks pirate king000 please post pics of your antec aria installed in that baja. I should be done by spring.
  1. Power Supply Without Opus
    By chewy747 in forum Power Supplies
    Last Post: 09-15-2004, 04:45 AM
  2. power supply that monitors voltage
    By dim-8 in forum Power Supplies
    Last Post: 03-18-2004, 09:09 AM
  3. the perfect power supply
    By agent_86 in forum Power Supplies
    Last Post: 12-08-2002, 06:39 PM
  4. DC-DC car power supply for ITX case
    By mrandery in forum Power Supplies
    Last Post: 08-30-2002, 09:30 AM
  5. AT power supply questions
    By JustAGuy in forum General Hardware Discussion
    Last Post: 07-26-2000, 05:35 AM
