Results 1 to 10 of 15
Thread: Has any one had any luck converting a standard PC power supply to a DC to DC unitl?
    Nov 2003
    Kansas City, MO
    Hi,
    In doing some preliminary research for my car PC project everything I have read has said trying to build a DC to DC power supply is not worth it. And have suggested buying an off the self unit. I was wondering if any one has any luck trying to convert a standard PC Power supply to a DC to DC.
    I ask because I have 3 350w units collecting dust that I would like to use for something.
    Thoughts?
    Variable Bitrate FyreDaug's Avatar
    Jan 2005
    Saskatoon, SK
    I extremely highly doubt its possible.
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    someone did it, they had to rewind the transformer, from what I remember it was noisy and didnt have a whole lot of power.
    肚子笑痛了
    S60 Install
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    I think OPUS is the answer you are looking for
    TruckinMP3
    Read the FAQ!
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Yeah, not possible if I remember right, cause the AC side converts to alot higher voltage than 12v dc. It jumps it pretty high, then the DC part takes that and steps it down to the 12, 5, and 3.3 stuff. From what I've read anyway.
    Tidder
    Try RevFE
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    It can be done. There were a couple of sites around that showed it done, but none of them gave you a real lot of detail on how to complete the mod successfully. You need to know exactly what you are doing before you embark on trying this. My suggestion is, that unless you are very experienced in electronics, I would lokk at other options. The best two options are look at Mastero's kit or buy a commercial unit (read opus).
    Oct 1999
    London England
    presslab
    Will return loads of threads about rewinding transformers. Not done it myself though.
    Jun 2002
    Colorado
    Do you really what to risk it? You could damage yourself and any component to hooked up to it.
    TruckinMP3
    Read the FAQ!
    Sep 2003
    Vic. Australia
    There is definately a post somewhere on this forum about it coz I remember looking into it. There are various tutorials and yes, they involve winding a transformer. I would imagine it would be difficult to follow a tutorial on this as most power supplies are different inside (although they would have the same basic configuration).
    Low Bitrate crazymadbastard's Avatar
    Jan 2005
    Connecticut
    Quote Originally Posted by Tidder
    this is the way I always thought the ac p/s worked. Seems doable.
    Iwill ZPCgx 2.4ghz cel, 256mb pc2700, external combo drive, 80gb 2.5 laptop drive, xp pro, usb gps, 7 in Lilliput TS , carnetix CNX1900. All mounted ghetto- still experimenting and tweaking.
  1. DIY DC power supply???
    By lopan in forum Power Supplies
    Last Post: 03-23-2007, 01:18 PM
  2. zootjeff's DC to DC power supply and hard drives
    By Squeezer in forum Power Supplies
    Last Post: 11-05-2002, 09:50 PM
  3. what is the cheapest DC to DC ATX power supply available?
    Last Post: 07-29-2002, 02:17 PM
  4. PC Power & Cooling 12V supply
    By driney in forum Power Supplies
    Last Post: 03-13-2002, 07:32 AM
  5. book pc power supply AC filter
    By enlight22 in forum Power Supplies
    Last Post: 12-14-2001, 06:56 PM
