Results 1 to 10 of 16
Thread: Epia M1000 and Hibernate
    Variable Bitrate HummDinger's Avatar
    Aug 2004
    Milwaukee, WI
    Is it possible to enable hibernate using my epia M1000 board. I tried searching and yeilded nothing.
    I am running XP and it has no choice for shutdown options except to turn off. Just curious if I missed something while looking through the bios or if there is a jumper setting I need to set. Otherwise Im stumped.
    Im also using the m1-atx PSU
    Thanks in advance
    You can still have something if you have nothing
    Registered User mpattonm's Avatar
    May 2003
    Czech rep.
    Yes, you missed. Check "Enable hibernation support" in Power option control panel applet.
    Low Bitrate hondaguru's Avatar
    Jan 2005
    Valdosta, GA
    Hold the shift key while the mouse is on the standby button in the shutdown menu and standby will turn into hibernate and walaaa
    I dont have a sig
    Variable Bitrate silencery's Avatar
    Jul 2004
    Los Angeles, CA
    be sure you've got the video drivers installed. Advanced power down options aren't available unless you've got them in the system.
    Aug 2004
    Milwaukee, WI
    Ok then that is my problem. I do not have the video drivers at all. I tried downloading them from the VIA website but it is not the right one they have there. Any ideas
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    Are you sure you downloaded the right ones?
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
    Low Bitrate code-'s Avatar
    May 2004
    Haugsund, Norway
    Also, don't forget 4in1
    Aug 2004
    Milwaukee, WI
    Quote Originally Posted by stevieg
    PRetty sure anyway, I have an epia m1000 board and that is the drivers I downloaded. After installing the VGA driver I get really poor display 4bit, and 640x480 res. OH **** This sucks. Anyway Im running XP pro. Any one have any ideas at all?
    Jul 2004
    Los Angeles, CA
    urm... google for the proper drivers?
    btw, it's m10000, not m1000.
    Aug 2004
    Milwaukee, WI
    Quote Originally Posted by silencery
    I have googled, that is how I downloaded them. I also used the disk that came with the motherboard. Same results. I have a real issue here, anyone
  1. Wanting Epia to go to hibernation with power switch.
    By jnusaira in forum General Hardware Discussion
    Last Post: 06-21-2004, 01:46 PM
  2. Man, no luck with hibernate and standby modes - both are crashy any tips?
    By psyclobe in forum Software & Software Development
    Last Post: 12-23-2003, 11:28 AM
