Results 1 to 5 of 5
Thread: PW70A (Blown) Some help please
    Oct 2004
    Canada
    Hey
    I was messing around on the weekend and ended up touching my 12V line to ground and blew the power supply. Does anyone know the schmatics on this thing. So i can replace componets instead of buying a new one.
    If not I am just going to buy and Opus.
    Gord
    Oct 2004
    South Carolina
    you may be better off replacing it ...
    There also may be a surface mount fuse. The PW-60 units have a fuse that blows if you do just that sort of thing. It is close to the power connector on the PSU; and this is just an assumption, but the PW-70A may also have one.
    KyferEz
    TheCarPCStore.com - Power Controllers (SDC), Inverters, Tank Circuit, GPS, OBDII, CarPCs, and more!
    PSU Wattage Calculator
    Electronics Calculators
    Copper Wire Data
    Oct 2004
    Canada
    Yes I know about the fuse but that is on the input
    I touched the +12V on the output.
    Oct 2004
    Canada
    I solved the problem
    On the PW70A there are 3 fuses
    1 on the incoming 12 V line
    The one I blew was F3 I guess it is hooked up to the output line
    Im guessing the 3rd on is on the 5V line
  1. ITPS + PW70A = Random Shutdowns / Reboots
    By tbird2340 in forum Power Supplies
    Last Post: 01-14-2005, 11:25 AM
  2. FS: Opus 90w and PW70a
    By BlueF in forum Classified Archive
    Last Post: 11-02-2004, 10:29 AM
  3. No more 5v on PW70A
    By SAScooby in forum Power Supplies
    Last Post: 06-01-2004, 02:10 AM
  4. PW70a directly to car battery
    By petera in forum Power Supplies
    Last Post: 02-03-2004, 11:59 AM
  5. Epia M10000 + PW70a + car startup
    By SuperSonic in forum Power Supplies
    Last Post: 11-27-2003, 02:21 PM
