Results 1 to 10 of 15
Thread: ITPS help
    Variable Bitrate 4u2n's Avatar
    May 2004
    Denmark
    Unhappy ITPS help
    Please help
    Can someone post the orginal ITPS hex file
    my Pic chip is burn off on my ITPS
    I have a new chip and a programmer, so i only need the hex fil to make it again
    Plan for project = 100%
    Part the project. = 100%
    Built...................= 99%
    Finish.................= 99%
    Install ...............= 99% -50%
    Ditail at 4u2n.dk
    Here
    May 2004
    Denmark
    is that right that nowone can't help
    Ditail at 4u2n.dk
    Here
    Jun 2004
    Central California
    Did you google it? I found it through google. It's on a PDF file on via.com.tw site.
    Edit: Forgot to include this: search for "itps microcode"
    EPIA Nehemiah M10k, M1-ATX, 20GB 4200 RPM 2.5", 256MB RAM, Win XP Home, Gyration RF Keyboard & Mouse, Zoltrix Nightingale Optical 4.1 PCI Sound Card, Lilliput 619GL-70NP, XM-PCR w/ optical upgrade, Garmin GPS-25LVS, Microsoft MN-710 USB Wireless NIC
    May 2004
    Denmark
    Quote Originally Posted by edikp
    yes I have this pdf file buth it the asembler code and i can't compile et to a HEX file
    Ditail at 4u2n.dk
    Here
    Jun 2004
    Central California
    Oops, my bad. You did say you wanted the HEX.
    The link they'd provided on the manual is no longer active, either. Have you tried to email mini-box.com?
    Jun 2004
    Central California
    Also, that pdf file has that Andrei guy's email on it. Perhaps you could try to email him.
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    I can compile this in assembler when I get home if you want
    肚子笑痛了
    S60 Install
    May 2004
    Denmark
    Quote Originally Posted by jcdillin
    yes thanks many times
    Ditail at 4u2n.dk
    Here
    May 2003
    Miami, FL
    does yours still have the stock mcu on it?
    肚子笑痛了
    S60 Install
    May 2003
    Miami, FL
    Allright I got it compiled for you, just PM me with your email address and I will send it over for you.
    肚子笑痛了
    S60 Install
  1. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  2. ITPS problems
    By numberone in forum Power Supplies
    Last Post: 10-29-2004, 05:07 AM
  3. ITPS Startup Shutdown Controller Not Working
    By EBJUSTIN in forum Power Supplies
    Last Post: 09-11-2004, 09:04 PM
  4. Voltage issues with ITPS?
    By mcrussell in forum Power Supplies
    Last Post: 06-06-2004, 11:48 PM
  5. ITPS and Voltage drop issues
    By Wiredwrx in forum Power Supplies
    Last Post: 04-20-2004, 07:09 AM
