Results 1 to 7 of 7
Thread: Opus trigger.
    Oct 2004
    Question Opus trigger.
    Is it ok to have the Opus 150w triggered from the head unit's amp trigger? Or should I trigger it from the ignition.
    Ta for your help.
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    As long as the amp trigger is sending a 12v signal its doing the same thing as the accessory power line
    Should be fine
    FLAC Chairboy's Avatar
    Jan 2004
    I trigger my Opus 90 w/ that line, works like a charm.
    Chrysler 300 - Fabricating
    http://hallert.net/
    FLAC djmickyg's Avatar
    Feb 2004
    try and triger it from the cars ignition.
    i was lazy when i did mine and went with the decks amp trigger..
    the deck usaly delays the amp for a second or 2 to prevent that anoying poping noise. and then the opus takes a few seconds to switch on aftr being triggerd..
    in other words witht he opus hooked to the amp out it can take about 5 secs to switch on and theres a fair chance of that pop..
    hooked up to the ACC and it will take less time to switch on and theres less chance of any pop
    Oct 2004
    I've got it hooked up to the acc at the moment, but I don't want the pc to come on whenever I switch the car on. I want it to come on when I want it on... If that makes sense. I had a switch between the ignition and opus in my previous car but that was a bit lo-tec.
    Jan 2004
    Another reason I use the headunit to signal power on, my car has a feature where the stereo stays on after you shut the car off until you a: open the door or b: 5 minutes pass, then it shuts off. It's a great feature for listening to the end of a song or radio segment without running the motor. By tying this to the HU, the computer stays on by the same rules.
    http://hallert.net/
    Nov 2004
    my car does that too, i can shut it off completely but if i dont pull the key out from the ignition the radio stays on.
  1. Opus remote trigger. Amp turn on
    By live2themaxuk in forum General Hardware Discussion
    Last Post: 09-08-2004, 03:37 PM
  2. Wiring two OPUS to one computer system
    By lookinco in forum Power Supplies
    Last Post: 09-07-2004, 11:23 AM
  3. Replies: 8
    Last Post: 06-05-2004, 10:13 AM
  4. FS: Opus 90watt with Remote Trigger
    By naevity in forum Classified Archive
    Last Post: 03-29-2004, 04:47 PM
  5. One reason not to buy the Opus
    By orangewhip in forum Power Supplies
    Last Post: 03-13-2004, 04:15 AM
