Results 1 to 5 of 5
Thread: opus somewhat powering on?
    Jul 2004
    Hi, about a week ago i installed an opus to my carputer instead of an inverter and a psu. system specs:
    epia m10000
    512 mb ram
    200 gb seagate
    150 watt opus
    liliput 7" touchscreen
    I did not wire the opus to the ignition, instead i use a switch to turn the computer on/off. The opus has been working great up until yesterday. While driving, it seemed like the computer went into sleep mode. After a bit of driving, i wanted to listen to some music so i tapped the screen to get it out of sleep mode. The computer would not come back. I checked the LED on the power switch and it was solid. I turned the computer off, then back on, the LED would light up, which shows that its getting power, but the opus fan is not spinning and the opus is flashing 4 times.
    Has this ever happened to anyone? Could my opus have suddenly died on me?
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by Rudsky
    epia m10000
    512 mb ram
    200 gb seagate
    150 watt opus
    Well, did you wire it up correctly? and did you re-check all the connections?
    Jul 2004
    everything is wired correctly and all connections are good. I cant seem to figure out the problem. Still getting 4 flashes.
    Oct 2003
    Madrid
    Did you read the manual to see what 4 flashes means?
    Oct 2004
    this is the same problem as me. =(
  1. Help!! OPUS not powering
    By Mush in forum Power Supplies
    Last Post: 02-21-2005, 07:38 PM
  2. Opus not powering on VGA/Sound
    By TheGeneral in forum Power Supplies
    Last Post: 10-04-2004, 02:01 PM
  3. Relays & Powering Opus
    By [iG] in forum Power Supplies
    Last Post: 06-19-2004, 11:02 AM
  4. Opus 150 and PW-70a powering one carputer
    By Altimat in forum Power Supplies
    Last Post: 05-19-2004, 12:43 PM
  5. Strange problem powering xenarc from 90w Opus :(
    By Brettster in forum LCD/Display
    Last Post: 05-11-2004, 06:19 AM
