Results 1 to 4 of 4
Thread: Another Power supply question
    Feb 2005
    Oklahoma
    I am new to this forum but only after reading for a few days I have pretty much weighed my options and have made a decision. Though I am not new to building computers, building one for a car takes a little more thought.
    My computer will consist of the following components.
    ABIT "VA-20" VIA KM400A
    Zalman NP Heatpipe HDD Cooler
    Samsung 160GB 7200RPM Hard Drive
    SAMSUNG 16X DVD Drive Black
    Proxim ORiNOCO 11b Wireless (802.11b) LAN PCI Adapter
    AMD Athlon MP 2800+
    Corsair Value Select 512MB
    Dynatron DC1206BM-L CPU HSF
    Triple fans Cooler(modded to case for airflow)
    using the power calculators that were posted I come up with 164W total power. I was looking t using a Opus 150W since it seemed the easy to use and install. I was just wondering if I should go for a different PSU since my total watts are more that the Opus is rated, or use it since the not all the devices will be using max power all the time.
    Suggestions or comments are welcome
    thanks for helping a n00b
    Jun 2005
    sorry to not answer your question, but i just scrapped an Athlon MP Dual machine at work, and I'm left with a bad mobo and 2 1.2ish athlon MP processors. can i use a standard atx/micro-atx mobo with the athlons instead of getting one of the "mini-itx" VIA board/processor combos? i am having the same problems getting my total wattage below the target 150w (for the Opus 150 system). let me know if you have any luck. your system sounds similar to what i'm going for
    a.tow
    toyota avalon carputer progress -- 0%.
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    I use a mobile xp on a cheap ecs mainboard and no problems at all
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    The Carnetix P1900 is 190 watts. May work for you.
    Want to:
  1. Replies: 5
    Last Post: 06-16-2004, 01:41 PM
  2. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
  3. the perfect power supply
    By agent_86 in forum Power Supplies
    Last Post: 12-08-2002, 06:39 PM
  4. More info on OPUS automotive ATX power supply
    By InvisiBill in forum Power Supplies
    Last Post: 08-16-2002, 03:19 PM
  5. Power Supply & TFT LCD question
    By VegaBOND in forum General Hardware Discussion
    Last Post: 03-23-2000, 07:07 PM
