Results 1 to 4 of 4
Thread: opus wired to wires from radio
    Aug 2004
    I am going to take out my double dinn radio and install a carputer. I am wondering if I can hack the wiring harness from my factory stereo to use the 12V constant for the opus. I know that I can use the ignition wire and probably the ground also, but Im not certain if the 12V constant will provide enough Watts to power the opus. Or do i HAVE to wire the opus 12V constant directly to the battery (fused of course).
    Maximum Bitrate Vchat20's Avatar
    Jan 2005
    Warren, Ohio, USA
    yeah. id like to know as well. ill be replacing the headunit altogether in my carpc, so the wiring harness for the radio will be left open.
    Your everyday carpc geek and tech guru at your service. *bow*
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    Do so at your own risk. The instructions for the Opus state it should be connectected to the battery for the main power. It is acceptable to use the ACC/ignition on line for the Opus 'switch' though.
    For an extra 30 mins work to wire to the battery it could save your car from setting on fire. OK chances are it will be fine but unless you know you car's own wiring well, it's not worth risking.
    Ford Focus MP3 : Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
    FLAC ppgt94's Avatar
    May 2001
    At least use an in-line fuse.
  1. 86% Efficient AC-DC ATX supply
    By auto_robotics in forum Power Supplies
    Last Post: 11-25-2004, 03:16 AM
  2. Opus not powering on VGA/Sound
    By TheGeneral in forum Power Supplies
    Last Post: 10-04-2004, 02:01 PM
  3. Opus 150 and System issues
    By septicdeath in forum Power Supplies
    Last Post: 09-17-2004, 12:38 AM
  4. Replies: 16
    Last Post: 07-30-2004, 01:46 PM
  5. Should everything be powered by OPUS?
    By c0rrupti0n in forum Power Supplies
    Last Post: 04-25-2004, 11:38 AM
