Results 1 to 9 of 9
Thread: Best way to get power to cpu and touchscreen???
    Feb 2005
    NJ
    I'm about to install a cpu with the M1-ATX and an indash touchscreen. I've been reading a lot of threads, but was wondering which would be the best and easiest way to get power to the cpu and touchscreen. I've narrowed it down to three options:
    1. Connect the power wire to the blanks in the fuse box using spade terminals
    2. Connect the power wire directly to the battery's positive terminal
    3. Splice the power wire in with the power wire behind the cigarette lighter
    Also, is the power wire just regular 12V Primary Wire and do the ignition wires just need to be connected to any wire that receives power when the car is either on or in accessory mode?
    Any help would be appreciated! Thanks
    #2 is the safest.
    Edit: I read this a bit wrong. I took it for granted that the M1-ATX would be used to power everything. Thus, when I posted I meant it's safest to run power wire directly from the battery's positive terminal to the M1-ATX, then use the M1-ATX to power the cpu and screen. Sorry I didn't clarify before.
    Yes and Yes
    KyferEz
    TheCarPCStore.com - Power Controllers (SDC), Inverters, Tank Circuit, GPS, OBDII, CarPCs, and more!
    PSU Wattage Calculator
    Electronics Calculators
    Copper Wire Data
    FLAC -zip-'s Avatar
    Ontario/Canada
    What type of power supply are you using and inverter? opus?
    I would use battery to power supply then 12v from the cpu to the screen for a regulated 12v. If your screen needs 12v.
    Sound Stage
    Eclipse|MTX|Infinity
    Registered User Nicorolla's Avatar
    NB,Canada
    Quote Originally Posted by KyferEz
    #2 is the safest.
    Yes and Yes
    KyferEz
    I agree, #2 is the safest but you must add an inline fuse. This is very important.
    Feb 2005
    NJ
    ZIP - I'm not really sure yet, i havent put the system together yet and am mapping everything out first.
    Nicorolla - is the inline fuse the same thing as when connecting an external amp for your stereo? And this is necessary directly connecting the battery to the M1-ATX?
    Jan 2005
    Richmond, VA
    dude if its 12 volt then i think it would be better if u run a molex connector or a usb perhaps.
    NB,Canada
    Quote Originally Posted by kasemodz
    usb is 5v
    FLAC ppgt94's Avatar
    May 2001
    USA
    Quote Originally Posted by Berg997
    Yes and probably yes, that wold be best. Infact, a amp powering kit is a perfect start.
    Constant Bitrate vortex's Avatar
    Feb 2005
    London, UK
    I did mine using an amp wiring kit and now i've just seen this thread with looks like a better method M1-ATX and how I did it...
  1. Power Problems. Please help.
    By RPM_VR4 in forum Power Supplies
    Last Post: 12-01-2004, 03:21 PM
  2. cool mini computer LCD touchscreen
    By turbochris in forum Classified Archive
    Last Post: 08-30-2004, 10:26 AM
  3. Lilliput touchscreen problems -- Need Help
    By BrUTaL in forum LCD/Display
    Last Post: 08-20-2004, 09:41 PM
  4. fs: 12.1" ELO TOUCHSCREEN KIOSK PC LOADED
    By Motorcity in forum Classified Archive
    Last Post: 07-10-2004, 04:30 PM
  5. Lilliput USB driver CPU usage question.
    By AustnJPR in forum LCD/Display
    Last Post: 04-06-2004, 02:59 PM
