Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Powering up PC using central locking...?
    Feb 2005
    I am pretty sure there is not already a thread on this... but sorry if there is...
    I was wandering if it would be possible to power on/off a carPC using the remote central locking system in a car? I am actually a PC engineer but i am not that good with car electrics...
    Any info would be a great help.
    J.
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    Absolutely. You basically need to find the "unlock" wire in your car and wire into that. Depending on the power supply or the setup it will differ for you though. If you have a laptop, its a matter of running power to it, and then pushing the button in some way. This is how mine was supposed to work. You also have to keep in mind to disable this feature if the computer is on though. So that you don't trigger it again accidentally.
    I don't have an OPUS, so I have no idea on how they are triggered. I think it is all triggered off of the accessory voltages though. If the power supply gets power to the trigger wire, it turns on. If that same voltage goes away, the computer gets shut down. Other than that I have no idea.
    I tried to build something myself, but the weather got too bad to spend any time out there to actually install it.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
    Nov 2003
    Marietta, GA
    JimBob,
    As KiltJim says, it's a matter of how the power supply is triggered. Here's an example of the CarNetix triggering ("Pulse Start").
    MikeH
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    Here is a link to someone's install who has done very similar to what you are looking for..
    http://www.digital-car.co.uk/forum/viewtopic.php?t=674
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    i used to do this, i had a relay on the central locking "unlock" wire, so everytime i unlocked it would press the power button, it became a pain in the *** in the end
    Signature: [==||========] 20% complete
    Oct 2003
    Chicago, IL
    use a relay to convert the unlock pulse into a constant that connects the opus ignition wire to +12V battery, that'll turn the carputer on i think
    Elsewhere
    Quote Originally Posted by Dexter
    Actually, it would be simpler to have a momentary short across the ATX power-o headers for the motherboard (assuming your motherboard meets ATX spec).
    Logically, your way would work as well, I believe, just more of a pain to implement.
    How about the Wiki?
    Oct 2003
    Chicago, IL
    maybe its because ive been up all night half assedly coding, but how would the computer get power if you only short the power switch? would the opus turn on anyways, even though its Ignition wire isnt high?
    i must have a gift for coming up with 'pain to implement' solutions ... i should patent that or something...
    _
    Mar 2004
    Little Elm, Texas
    lol
    the way I have mine set-up is that the computer turns on with ignition via remote start. The screen won't come on unless the key is in the ignition, that way if I remote start it while left in the parking lot, the screen won't be advertising to everyone out there...lol
    I don't see remote unlock being that difficult to wire into, I guess you could also wire into it to send a signal to shut down once you get out of the car and hit the lock button?
    Jan Bennett
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Quote Originally Posted by Red GTi VR6
    lol
    Nice idea with the screen Red, i think i will do that.
    I am planning on having it boot with the central locking too. Gonna use a pulse setup as described above but also have the ign in parrallel so i can lock the doors while driving (e.g. when is St Pauls or Manchester) and not have the PC shutdown.
  1. Car 5.1 Dsp Options Vs Pc 5.1 Dsp
    By port20 in forum Car Audio
    Last Post: 05-29-2006, 03:10 AM
  2. External PC Card adapter for Verizon BroadbandAccess
    By Bluebisz in forum Wireless Communications
    Last Post: 02-24-2005, 10:11 AM
  3. need everything for a PC in car??
    By Hollis613 in forum Wireless Communications
    Last Post: 04-23-2004, 02:42 PM
  4. home pc problem
    By Mitokondria in forum Off Topic
    Last Post: 08-05-2003, 12:36 PM
