Not sure how much of this you've built, but there are currently a total of 3 different professionally manufactured SDC's designed for use with Inverters...
CarPC Pro/EZ
Dashwerks SDDC
uSDC(sp?)
-HD
those who dont know already, i have decided to go the inverter route for my carpc. so i decided to try and design my own simplistic shutdown controller. here is my diagram. tell me what you think:
for those curious, here's how the setup works:
Key On: Relay #2 (middle) turns on inverter and relay#1 (left) momentarily activates the power switch on the motherboard and computer turns on. when the computer turns on relay #3 (right) adds an extra closed ciruit to the inverter power switch.
Key Off: Relay #2 turns off and removes the first closed circuit from the inverter switch, but relay #3 is still on so the inverter stays on. relay #1 pulses the motherboard power switch again which shuts down (or hibernate, your preference) the computer. once the computer goes off, the 12V power is removed from relay #3 which ends up opening the last circuit keeping the inverter on. at this point the inverter shuts off.
Your everyday carpc geek and tech guru at your service. *bow*
CarPC Pro/EZ
Dashwerks SDDC
uSDC(sp?)
-HD
Think I've seen similar circuits here that used 2 relays and some diodes, to do the same thing.
1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
someone really should make this a sticky.
Ghetto Startup/Shutdown Control for Inverter
I guess its just something that I'm going to have to live with for now, but everytime I see this I get excited. Unfortuately I have a laptop. And none of these methods help. I know its just as easy as flipping a switch, but oh well... (I could just let my laptop shut itself down on battery power, if the battery was any good...)
2000 Subaru OBS
Dell P3 @ 900 Mhz
7" Lilliput TS w/DigitalWW in-dash mount
80GB External HD
I am Zero Bitrate....
