Results 1 to 4 of 4
Thread: Control switch
    Variable Bitrate warnockm's Avatar
    Jun 2004
    Control switch
    I'm looking into building a switch in my center console as sort of a "control switch" or switches i should say. I would like a switch the lets you control an opus power supply to have it turn on with the ignition, turn on all the time and just be turned off. I would also like a reset switch. Has anyone wired anything like this? I'm curious what would be the best approach. Where can i get a 3 way switch for the power supply, and I'm assuming a reset switch is just a momentary switch. Also, how can i make the reset button "hidden" so i don't accidently restart the computer. Does anyone have any suggestions or ideas?
    Progress - VIA EPIA SP8000 | 120 Opus Power Supply & Case | 1GB Ram | 120GB 2.5" Hard Drive | Bluetooth 2.0 | GPRS/3G | Wifi | Road Runner/LSX 2.0 (waiting for a day skin for 3.0) | iGuidance 4.0 | Lilliput 7"
    Jun 2004
    Im looking for this too. Did you find a good thread? I had one at one time but searching for this is a pain with all the hits you get
    Dec 2004
    Miami, FL
    I rigged a switch to my ACC line so I can make the computer think the car is off when it's on, so the computer wont boot (or will shutdown when I flip the switch off). But I haven't done anything to keep the computer running after turning off the car.
    Variable Bitrate rubicon's Avatar
    Feb 2005
    $240 worth of puddin'
    Well, you could theoretically run, say, CAT-5 wires (individually) to the headers on a board like the M1-ATX to control its behaviour, and wire up switches on the other end. Also, you can use a jumper to hook the PSU into the mobo's on/off switch line, and wire that up as well.
    I briefly thought about doing this, but then decided it wasn't that important.
  1. Capture GPS data at the flip of a switch
    By Mr. Inquisitive in forum GPS
    Last Post: 02-02-2005, 07:06 PM
  2. Savage Switch Botton Group Buy via UK's
    By TheBigDog in forum General Hardware Discussion
    Last Post: 07-21-2004, 11:51 AM
  3. Need clairification on wiring on/off switch
    By syclone477 in forum Newbie
    Last Post: 03-23-2004, 05:59 PM
  4. Help With Extending Laptop Docking Station's Power Button
    By JeffesonM in forum General Hardware Discussion
    Last Post: 04-14-2003, 02:13 AM
  5. Some sort of switch board...?
    By claylong in forum General Hardware Discussion
    Last Post: 01-14-2003, 08:17 PM
