Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Blew my M1-ATX
  1. #11
    Feb 2005
    So I blew the replacement. Attaching the LCD, the barrel connector inside touched the female outside, small little pop. More money down the crapper.
    Has anyone else had this problem? Pin 2 on Q2 blows whenever the ground/power of a peripheral get reversed.
    Are there other power supplies that have protection against this? Perhaps a fuse?
    -w
    P4MST-890 775 MicroATX Pentium Dual Core E2140 , 80GB 2.5", OPUS 320W, MS GPS, SB EXTREMEGAMER PCI, 8" LILLIPUT TS, 15" NEC TS, SIRIUS USB PC INTERFACE, STREETDECK, KICKER ZX850.4, KICKER 2500.1, 2xKICKER SS65.2, 2xKICKER 10"COMPVX
  2. #12
    Maximum Bitrate Change's Avatar
    Aug 2004
    California
    I hate those barrel connectors, it's too easy to short the supply to ground unless you insert it *just* right. Whenever I have to plug one in, I try to make sure the connector is unpowered.
  3. #13
    Feb 2005
    Yeah, me too, in fact, just prior to doing this I was touting the fuse I keep inline to prevent this from happening. Unfortunately, the barrel connector seems to have a stretched wire or something inside, because you have to twist it etc. to get power into the LCD. So it had to have power applied to test it, thus my predicament.
    -w
  1. Replies: 7
    Last Post: 06-15-2004, 09:29 PM
  2. BLEW two ATX PSU's with inverter?? HELP!
    By aznblueeboi in forum Power Supplies
    Last Post: 04-06-2004, 07:13 PM
  3. ATX board power??
    By Alphared in forum Power Supplies
    Last Post: 01-10-2003, 12:36 PM
  4. ATX and AT motherboard
    By Beavis in forum Power Supplies
    Last Post: 05-10-2001, 02:22 PM
  5. ATX to AT conversion?
    By drew in forum General Hardware Discussion
    Last Post: 10-27-1999, 01:28 AM
