Results 1 to 10 of 13
Thread: Blew my M1-ATX
    Feb 2005
    Blew my M1-ATX
    So it turns out the (-) sign on the spare lcd power connector indicates the positive line, not the negative line. Either that or the black line on the power supply is positive. Either way, I blew my first M1-ATX.
    Anyone else done this or am I just a schmuck?
    -w
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    spare lcd power connector?
    _
    Mar 2004
    Little Elm, Texas
    what are you talking about? spare lcd power connector on the m1?? hu??
    there is no such thing!
    Jan Bennett
    Maximum Bitrate contaygious's Avatar
    Feb 2005
    The Yay Area (SF)
    Quote Originally Posted by waltwalt
    -w
    that's dumb thanks for telling me id probably do the same thing
    Peep MY TYTE WHIP yo! It's got too many ill mods to list!
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    Maybe hes talking about the amp turn on? or the Aux Momentary?
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
    VENDOR - ITuner/MiniBox
    Nov 2003
    Just send it back to mini-box.com, but please let us know what you did.
    We will send you another one.
    -A
    -w
    Mar 2004
    Redondo Beach, CA
    Hey I'm going to fry mine too -- I really want a "spare LCD power connector" too!
    Feb 2005
    Settle down with the sarcasm there rondo, the spare lcd cable you can purchase from this site is what I am referring to.
    Hook it up backwards and you blow an IC on the psu, my fault, almost definately not covered unter warranty.
    -w
    Feb 2005
    PS. AndrewB: I've already got another psu on the way from mp3car, next day air delivery, so it should be here tomorrow.
    Mar 2004
    Redondo Beach, CA
    -w
    Your post along with the thread title made it entirely unclear what you meant. I assume (now) that you are referring to the product sold here called the "Extra Monitor Power Cable"? If I'm looking at that right, it's just a barall plug with two wires coming off of it. The correct way to wire it is dependent on your monitor and has little to do with the M1-ATX.
    In any case, it sounds like what you did was hook the 12V output of your M1-ATX strait to ground. If so, that's the key information that Andrew would probably want to understand since ideally the PSU might be designed to protect against this kind of situation (i.e. overload or short circuit protection).
    Sorry for the sarcasm -- I just wanted to better understand what you did since your post made it sound as if the M1-ATX had some obvious design defect.
  1. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
  2. BLEW two ATX PSU's with inverter?? HELP!
    By aznblueeboi in forum Power Supplies
    Last Post: 04-06-2004, 08:13 PM
  3. ATX board power??
    By Alphared in forum Power Supplies
    Last Post: 01-10-2003, 01:36 PM
  4. ATX and AT motherboard
    By Beavis in forum Power Supplies
    Last Post: 05-10-2001, 03:22 PM
  5. ATX to AT conversion?
    By drew in forum General Hardware Discussion
    Last Post: 10-27-1999, 02:28 AM
