Results 1 to 7 of 7
Thread: Inverter and shutdown controller
    Jan 2005
    I have a great inverter. No noise, but I obviously can't shut it down. I have a power on and power off switch in my console with the pc in the back. Should I just get the car ez pc shutdown controller on the mp3forum or buy something else to piggyback on the inverter. Thanks for your help.
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Any of those shutdown controllers will work.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Stank Cheese n8scstm's Avatar
    Oct 2004
    Eastvale, Ca (Near Corona)
    You want to shut off the inverter too? Or just the computer?
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    8" Lilliput touch screen
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    Maximum Bitrate hd54321's Avatar
    Jun 2004
    Los Angeles
    You can hardwire a switch to the inverter to turn it off manually. BUT, you will soon realize that you will have to wait for the computer to shutdown prior to you manually switching off the inverter. So, you can purchase a SDC to shutoff the inverter when it knows that the computer has shut off.
    Goto thecarpcstore.com for the Car PC EZ/Pro v. 2.4. It's a great controller and I would highly recommend it.
    -HD
    Dec 2004
    CT
    i have the shutdown controller turn on and off a 30 amp relay, that controls the 12 + line into the inverter, and i just leave the switch on, it works fine
    Variable Bitrate Grimey's Avatar
    Feb 2005
    Moody, ME
    That looks awesome. Only question though, doesn't seem to be true, but does it work with a Mac Mini? It keeps saying PC everywhere but never mentions anything about Mac.
    Dak TruckPuter:
    Mac: - Researching and Awaiting Funds
    Changed to planning for a Mac Mini Trukputer...w3rd.
    Grimey, if you can use a pushbutton to turn on and off the mac (which you likely can), then the CarPC EZ or Pro power controller will work.
    All you have to do is see how the power button on the mac connects internally. If it has a cable that connects to the motherboard and uses a standard 2-pin .1" header, then it will be easy to hook up. If it has everything but the header, then it will require splicing into some wires, but is still pretty easy. If the button is soldered to the motherboard, it is doable, but will require soldering.
    The biggest thing is to make sure that it is a plain normally open pushbutton (meaning that when you push the button it makes connection) and that the mac will fully shutdown after you press the power button (or that you can configure it to).
    KyferEz
    TheCarPCStore.com - Power Controllers (SDC), Inverters, Tank Circuit, GPS, OBDII, CarPCs, and more!
    PSU Wattage Calculator
    Electronics Calculators
    Copper Wire Data
  1. custom shutdown controller for inverter usage
    By Vchat20 in forum Power Supplies
    Last Post: 02-28-2005, 11:59 PM
  2. El cheapo Shutdown controller
    By Nicorolla in forum Power Supplies
    Last Post: 01-25-2005, 03:59 PM
  3. How many wires go to the shutdown controller?
    By Skipjacks in forum Power Supplies
    Last Post: 12-23-2004, 09:51 PM
  4. Shutdown / Start up controller with an inverter?
    Last Post: 12-18-2004, 08:56 PM
  5. Replies: 2
    Last Post: 12-05-2004, 02:51 AM
