Results 1 to 6 of 6
Thread: shutdown software - fake usb - few questions
    Variable Bitrate will1384's Avatar
    Feb 2005
    Jefferson, AR U.S.A
    shutdown software - fake ups - few questions
    I want to use the shutdown software posted here
    New shutdown controller - software
    And talked about here
    Ghetto Startup/Shutdown Control for Inverter
    and here Inverter Shutdown controller
    And I want to make sure I have understood what a I read - I am a little
    slow - LOL -
    I redrew the circuit for what I needed - and I want to check to see if
    I drew it correctly - I will check it with a volt meter to make shure
    I want to park the car with the car off and the computer stay on for
    say like 10 min and shut off if I dont return - and if I do return before
    10 min and start the car its like I never left - and I dont have $$$ but
    I can spend the $5 for the relay tho
    I am worried about a dead battery - My inverter says it will shut off
    at around 10v - some thing tells me 10v wil not start my car
    I guess it will keep it from killing my battery
    I also want to know if using that software, has windows locked up
    and killed your battery and what you did to prevent it next time
    Feb 2005
    Jefferson, AR U.S.A
    Holy crap it works !!!!!!! - thanks for the ideas - I did run into a problem
    I need to use another relay to shutdown the power to the datalux
    LCD - because I used the computer to power it - and even when
    windows uses software to shut the monitor off - the back light stays
    on - so when I park the car you would see a lit up blank screen -
    thats bad - - but yes it works
    Maximum Bitrate carpcnoobie's Avatar
    Mar 2004
    Do you have info on the diodes you used??
    Congratulations on your success. Diagram looks good. Obviously works well too.
    Progress Meter:
    [|||||!||||'] 95% complete
    It's in... it's finally installed!!!! But never finished!
    "It works! It works! I've finally invented something that works!" -- Doctor Emmit Brown
    Feb 2005
    Jefferson, AR U.S.A
    I asked my dad if he had some spair diodes and he said to use
    Rectifier Diodes and handed me 2 big looking diodes - he knows
    his stuff - I did not ask what it was - I would guess a
    1N5401 would work its 3a 100v
    Here is a web site that might help
    Basic Electronics For Model Railroads - Diodes and Rectifiers
    and here
    Diodes
    and here
    Diodes 2
    Mar 2004
    Thanks for the links and info.
    Progress Meter:
    Feb 2005
    Jefferson, AR U.S.A
    Unhappy
    The shutdown software crashed - 2 times - I had that felling last night
    and checked my car at 3am only to find the red light on my mouse lit
    - and the car was a little slow to start but did, the computer ran from
    8pm to 3am
    I switched the "pin 4" to 87 instead of 87a and now use the built in
    ups software in windows - I hope I can get the shut down software
    to work some day - or make windows wait 10min to shut down
  1. Replies: 15
    Last Post: 05-04-2006, 04:53 PM
  2. Software USB to Serial Bridge?
    By 8threeSD in forum GPS
    Last Post: 01-10-2005, 03:33 PM
  3. Replies: 1
    Last Post: 08-25-2004, 11:29 AM
  4. Replies: 4
    Last Post: 04-06-2004, 09:52 AM
  5. Via Epia Questions - need multiple serials, ps/2 ports, USB
    By nxt125 in forum General Hardware Discussion
    Last Post: 08-07-2002, 08:08 PM
