Results 1 to 10 of 11
Thread: opus PSU too weak for me?
    May 2004
    Vic, Australia
    i've been reading this site for the last two days straight trying to learn about getting a carputer installation going.
    i've come to the conclusion that instead of an inverter i'll just fork out more money to get the 150watt opus dc-dc psu.
    i'm planning to run an old P3 500mhz computer with 384mb ram, 2 HDD's, 1 DVD player and possible some USB stuff too.
    i've searched and used one of those psu calculators, and it comes out to about 200-215watts.
    will i be better off getting a stronger PSU with inverter? or will the OPUS be sufficient even though its under my required wattage?
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Remove one of the HDs.
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    It may be sufficient - a number of people have claimed to put considerably more than the stated load on the opuses. And your calculation is probably the cumelative peak draws, which you'll probably never actually see. Still I'm not so sure it's such a good idea though, as you risk reduced lifespan of the opus, or spontanious shutdown when say the 3 drives happen to spin up simultaniously.
    If I were you, I'd try to stick with the opus (they really are quite nice) but try to trim the consumption side. Do you really need 2 HDDs? Or 384MB of RAM?
    May 2004
    Vic, Australia
    i suppose i could cut down the ram to maybe 256.
    i was going to use 2 hdd's cause i have 2 40gb hdd's in the computer atm, guess i could go out and buy like a 120gb! possibly have no dvd drive for the moment too.
    Elsewhere
    Quote Originally Posted by gummybear
    What kind of video card?
    Higher-end 3D cards can draw a substantial amount of juice....
    How about the Wiki?
    _
    Mar 2004
    Little Elm, Texas
    finding a place to put 2 hds might be a little difficult, or have you already test fit everything where you know you want it?
    I would just go and get one drive honnestly...
    Jan Bennett
    FLAC J187's Avatar
    Nov 2004
    Boston
    unless you wanted the 2 HDD for a raid array, I'd say get one single drive. Drives are gonna command a decent amount of that power, 20w+ for 7200rpm.
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
    May 2004
    Vic, Australia
    using an nvidia gf 4mx. don't think it'll chew up too much power, if not i'll go down to the OLD 3dfx voodoo 3 agp. lol
    yeh and i'll stick to 1 hdd.
    Constant Bitrate KaiTech's Avatar
    Forget a 3D accelerator... It's probably gona suck as much power as the rest of the system..
    I'll spout simplistic opinions for hours on end.
    Ridicule anyone who disagrees with me,
    and generally foster divisiveness,
    cynicism and lower level of public dialog!
    Nov 2004
    Cali
    Quote Originally Posted by KaiTech
    considering that it is a PIII 500 and the video card is a Geforce2 (yes, it is, its not Geforce4) the power consumption should be well within Opus limits. My PIII 700 takes at most 40Watts, so I would assume a 500 would take even less, and I believe the video card consumes at most 15-20 Watts, since it is a slower and castrated version of full-fledged Geforce2.
    I have found you an argument; I am not obliged to find you an understanding.
  1. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 07:25 PM
  2. Help: Opus + Slave PSU
    By ramy_zohair in forum Power Supplies
    Last Post: 01-20-2005, 10:22 AM
  3. Opus PSU for Casetronic C134
    By aethernaut in forum Power Supplies
    Last Post: 02-25-2004, 01:19 AM
  4. ITX PSU - What Alternitives Are There To The Opus One
    By ccsnet in forum Power Supplies
    Last Post: 05-28-2003, 07:41 AM
  5. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 02:07 AM
