Results 1 to 10 of 10
Thread: anyone have an inverter setup they've had good luck with?
    Feb 2005
    What inverter/controller/regulator power supply do you guys find that you like.
    Feb 2005
    Guess not
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    being old school, I used a 300w inverter for years before going DC-DC. You'll be much happier with the Opus and it's actually cheaper when you add a shutdown controller and a tank circuit to the inverter to get the funcionality of the opus.
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    Total spent on wedding so far: $3885.79
    Thanks to everyone for your support.
    I'M DEBT FREE!!
    No, The Opus is still more expensive, and doesn't offer quite as much.
    Inverter - Coleman PMP400 400wRMS modified. $50
    Power Controller - CarPC EZ. $60
    Tank - Tank EZ. $20
    Tank batt - 12v 7AHr. $22
    Total $152
    Opus 150 $195
    Benefits of useing inverter with CarPC EZ:
    1) 120 v for anything else that may need it
    2) Much more flexibility with timers and settings
    3) Control more than just your PC
    4) More features on the SDC
    5) Faster, more powerful PCs >3GHz are easily possible
    6) Depending upon several things including your wiring job, inverter, starter, and car battery, you may not need the tank circuit or tank battery to survive crank, which brings the total down to $110.
    Benefits of using Opus:
    1) All-in-one, easier installation
    2) Longer run-time off of car battery
    Feel free to add to the lists, I would like to see what others think belong in that comparison.
    KyferEz
    TheCarPCStore.com - Power Controllers (SDC), Inverters, Tank Circuit, GPS, OBDII, CarPCs, and more!
    PSU Wattage Calculator
    Electronics Calculators
    Copper Wire Data
    FLAC J187's Avatar
    Nov 2004
    Boston
    Actually an inverter is potentially much cheaper considering it allows you the flexability to use a reg dvd and a reg HDD instead of the slimline alternatives that are much more expensive usually.
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
    Maximum Bitrate TimmyM's Avatar
    Aug 2003
    Federal Way, WA
    Agreed. I'm very happy with my inverter. Which I can run other things if I have to, I.E. battery chargers for my cordless tools.
    I have a 150W/300W peak inverter powering a 200w PSU. I can't quote price on it since I got it in a trade from a friend. Made my own shutdown controller based on Laidback's design. Think I've got $25-$30 into that.
    The only disadvantage that I can see is the size. If you're limited on space, fitting a inverter in somewhere could be a problem.
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    If you went with the M1-ATX it would be even cheaper, its like $70~ and survives crank down to 5.7 volts.
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
    Aug 2003
    Federal Way, WA
    Quote Originally Posted by WebDog
    Certainly a good possibilty. BUT with the loss of being able to run other AC stuff and it's only 90W. Not sure if that would be enough for a full size MP/CPU setup.
    well it depends on his setup.
    1990 Jeep Cherokee
    Yes, but we are trying to compare devices that allow similar setups. Using the M1-ATX you can't even get close to the PC specs that are easily achievable with an inverter.
    KyferEz
    Copper Wire Data
  1. Inverter with Toughbook - humming problem solved
    By petemillis in forum Power Supplies
    Last Post: 11-02-2004, 02:12 PM
  2. inverter question
    By johnyeros in forum Power Supplies
    Last Post: 05-21-2004, 03:21 PM
  3. Replies: 2
    Last Post: 05-24-2003, 10:58 AM
  4. odd inverter behavior
    By jshrieve in forum General Hardware Discussion
    Last Post: 04-10-2001, 05:53 AM
  5. Where can I find a good and cheap power inverter?
    By Sk8te in forum General Hardware Discussion
    Last Post: 11-11-2000, 07:06 PM
