Results 11 to 20 of 25
Thread: M1-ATX + AMD Athlon Mobile!!
  1. #11
    Newbie halve85's Avatar
    Feb 2005
    so my Biostar M7NCG 400 (µATX with onboard sound & graphics) has just arrived! I installed my Athlon XP 1700+ (Palomino) on it. Underclocked the CPU to 1100Mhz and undervolted it to 1,3V Vcore.
    Now the power consumption:
    5V rail -> 5-6A
    3,3V rail -> 4A
    12V rail -> 0,2A
    System: Mainboard with Graphic & Sound onboard, CPU, PCI-WLAN-Card
    HDD will follow (small 2,5" will just consume 2,5W on the 5V rail)
    I'm very happy! I can use the M1-ATX now with my system!
  2. #12
    Dec 2004
    Sweden
    Quote Originally Posted by halve85
    5V rail -> 5-6A
    3,3V rail -> 4A
    12V rail -> 0,2A
    I managed also to buy a M7NCG-400. It works perfect with my Mobile Athlon
    XP-M +2400. I'm running the CPU at full speed 1800 MHz.
    I measured the following power consumption when stressing the system:
    5V = 6-7A (only 3-4A during normal Road Runner operation)
    3.3V = 4A
    12V = 0.3A
    Total power consumption of the M1-ATX = max 50-60 W. Including 1 x 2.5 HD, Slimline CD, 2 x 128 MB DDR PC2100 and a Soundblaster Audigy 2 ZS.
    I will also power my Lilliput from the M1-ATX. Maybe it's possible to power a setup like this with a 90W Opus.
    It's a quite fast setup, It beats my 1.7 GHz P4 desktop I'm satisfied now, 800 x 480 working and good sound quality.
  3. #13
    Raw Wave justintime's Avatar
    Apr 2005
    Hey olja...
    I'm considering the same mobo (M7NCG-400), with an Athlon Mobile CPU. Newegg has a 2200+ @ 35W and also a 2400+ @ 45W. They both cost the same ($79), so I wonder why not buy the 2400+, and if anything, underclock it for lower wattage.
    Do you know if this is possible to do? (underclocking) with this mobo and CPU?
    Also, how is the sound quality of the M7NCG-400? better than the M10000 EPIAs?
    Thanks a lot!
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  4. #14
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    I am considering going micro ATX and going with the biostar M7NCG-400.
    Can you tell about the S/PDIF out. Thats how i will be running the sound and it is a necessity. Also is the opus 90w a more powerful PSU than the M1-ATX?
  5. #15
    Dec 2004
    Sweden
    justintime: Yes, you can change Vcore, multiplier and bus speed on the M7NCG-400.
    I'm using a Soundblaster Audigy 2 ZS and have not tried the onboard audio.
    Antimatter: I have not tried the S/PDIF out. There is a connector on the mainboard, but no bracket was included in the box (listed as optional in the manual).
    I've tried to run my setup with both M1-atx and Opus 90W, no problem. But I think that the M1-atx it's better for my setup, 10 A on the 5 V rail compared to OPUS 6 A. I noticed that the Opus was running cooler than the M1-atx (measured with my fingertip). Ituner suggested to add some extra cooling to the M1-atx.
  6. #16
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    mobile 2500+ on ecs km400, boots up ad 600mhz (100*6) 1.45v then under windows I lset 1ghz 0.925v, rock solid and M1 ATX sustain it very well even under heavy cpu load
    to be honest I tried 1800mhz 1.6v and M1 still works perfectly, no problems at all at near 9A drain from the 12v imput
    by the way, take a look at this software for change multiplier-vcore under windows
    it also creates a shortcut to place in the startup folder (if you like)
    http://crystalmark.info/?lang=en
    enjoy
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
  7. #17
    Apr 2005
    So you are running the processor at only 1 Ghz? How fast did you manage to make it go? 1800 Mhz?
    Quote Originally Posted by Frankino
    enjoy
    2002 Honda CR-V
  8. #18
    Nov 2004
    Italy
    2000mhz 1.45v but it's pretty hot, I really prefer low power consumption for my carpc needs
    Peugeot 206 1.4 HDi
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    M2-ATX
    8" Lilliput TS LCD
  9. #19
    Jan 2004
    California
    what are the chances of running a regular AMD Atholon XP with the m1 ATX
  10. #20
    Jan 2004
    California
    Frankino, your signature says opus 150w. But you said this works on the m1-atx. Please clarify
  1. Help: Biostar MB w/ Athlon XP 2500+ Mobile = crash
    By C-speed in forum General Hardware Discussion
    Last Post: 06-16-2005, 05:27 PM
  2. Amd Athlon XP to Mobile Athlon Conversion
    By Quattro in forum General Hardware Discussion
    Last Post: 01-25-2005, 09:43 PM
  3. micro atx board and 1.3 ghz amd chip ith heatsink
    By scott_fx in forum Classified Archive
    Last Post: 01-21-2005, 04:59 PM
  4. Micro ATX / Mini ITX (AMD, Intel, VIA)
    By wanjer in forum Newbie
    Last Post: 09-11-2004, 08:31 AM
  5. Replies: 2
    Last Post: 04-16-2004, 05:04 PM
