That setup with diodes on definely works. I have used that same setup with a 9Ahr battery, for a month without any problem. But now i have a different setup since i am worrying about forgot to turn off the inverter and the main battery will go dead. Rather than putting a diodes in between two batteries, I use a relay. The relay is tapped to accessory 12+. In case someone doesn't know, the purpose of accessory wire is to cut off the power to radio, amp and other miscellaneous device so starter motor get all the current to crank the engine. In other word, the power is cut between main battery and small battery when it is during cranking state. This way, computer is running from small battery for few second. After you release the ignition key, the accessory get 12+ again, and your relay connected the main battery and small battery. But keep in mind, don't use too small wire connecting all the device. When your computer run off the main battery, once your small battery is drained. The next time you put your key in, you are charging up the battery with infiniti current as well as powering up your computer, so your small wire will get hot might result in fire. My 10A fuse almost melt, so don't run off your small battery from main battery for too long, unless you use all big thick wires...
LinkBack URL
About LinkBacks
