Results 1 to 10 of 10
Thread: Thinkpad T20 users.
    Low Bitrate Kato's Avatar
    Oct 2003
    Toronto
    Thinkpad T20 users.
    So I got my hands on a thinkpad T20 this weekend. When trying to put in a solder into the mother board, i think i fried the MLCC Caps ( multi level ceramic capacitors ). The laptop still boots but won't run off the battery anymore. Pic is attached.
    Can anyone tell how how/where i can find replacements for this.
    Also, has anyone been able to tap into the power on button in the keyboard to allow the laptop to be turned on with a relay. Its the push kind.
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    you sure one of those 2 fuses located near those battery terminals arent blown?
    and my t22 has a regular power button, not one on the keyboard you sure it's only on the keyboard?
    肚子笑痛了
    S60 Install
    Constant Bitrate RPI Geek's Avatar
    Oct 2004
    Schenectady, NY
    I've never taken my T20 apart, but my power button isn't in the keyboard either, and AFAIK the whole T** line is that way.
    Old plans out the window because of an accident .
    Have: M1-ATX, EPIA M10000, 256MB, 60GB 2.5", slim slot load DVD
    Need: Time, HU integration, ideas for Lilli
    Oct 2003
    Toronto
    Hmm..i'll look into the fuse near the battery terminal. Are they surface mount fuses....do you have a pic of what they look like.
    This is what i meant when i said that the power button in in the keyboard. How did you tap into it?
    Oct 2004
    Schenectady, NY
    That's a neat pic, I never knew that the upper row buttons & the mouse were attached to the keyboard.
    You could always do the slow & hard route and just trace the button back to the connector jack.
    May 2003
    Miami, FL
    that is very strange mine comes out as a separate piece
    肚子笑痛了
    S60 Install
    May 2003
    Miami, FL
    Here are the fuses
    肚子笑痛了
    S60 Install
    Oct 2003
    Toronto
    Thanks for the fuses...i'll check when i get home.
    Bizzarre thing is that i have removed the caps.....and yet the system is running ok . I tested with the multimeter and two of the three caps were allowing current to flow through ( possibly leaking ). As you can tell, i'm not an electrical engineer by any stretch of the imagination.
    I've done some more research..and this link provides some useful info. I have to find a dead mobo with those caps. Apparently people just replace them to mod their mobo's.
    http://www.xtremesystems.org/forums/...p/t-47991.html
    May 2003
    Miami, FL
    it could be a problem with the caps, but the fuses are simple to check
    肚子笑痛了
    S60 Install
    Oct 2003
    Toronto
    What are you guys using for a power adapter. It needs 16v @ around 3.6 to 4.5 Amps.
    I had an old 390e in my car first and had a dc adapter for it...unfortunately everytime i use that to power my t20 now, the computer re-boots randomly. I assume that its a power issue, since it works fine at home.
  1. Question to all users
    By netsuo in forum NeoCar Media Center
    Last Post: 12-13-2004, 11:57 PM
  2. EBAY: IBM T23 Thinkpad
    By migel628 in forum Classified Archive
    Last Post: 04-28-2004, 03:06 AM
  3. Newbee with Thinkpad 600e
    By Iceman in forum General Hardware Discussion
    Last Post: 04-06-2004, 01:41 PM
  4. To users of MPXF
    By AngryLlama in forum Software & Software Development
    Last Post: 09-19-2001, 02:33 PM
