Question: Did you do any testing of the complete setup running and playing some cpu/ram/hd intensive apps, like playing DivX? Or something less intensive like just playing mp3? Or were these individual tests simply powering the components? There is a big difference...
If you didn't test it with a processing load, you will find current consumption spikes quite a bit when you do. You will notice sustained current rates are higher, as well as peak currents even higher. It's something you should look into if you havn't already.
KyferEz
LinkBack URL
About LinkBacks
and does not suffer from bugs noted in other posts.
plus it fits my motherboard, PSU and HDD in perfectly.
spot on! Damn i threw one of those out last year. Wel actually someone else threw it in our bin and then my hosuemate found it and I threw it back in as we didnt have cable.
