Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Power USB hub from psu
  1. #11
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    no problem with this, its pretty much common sense stuff here.......i'll be powering most of my components with an ITPS & snapon PSU that I never ended up using. But remember if you drop power on the hub and repower it while the PC is on, you might loose your devices
    PC Components:
    My work log
  2. #12
    Maximum Bitrate DeltaFX's Avatar
    France
    A mobo's USB header only gives 500mA. That's enough for a passive HUB but if you plan to use devices like usb-powered Zip250, or a hungry webcam, it may not work, cause these devices needs each and every miliAmp.
    A common 4-port externally powered USB2 hub need 5V & 2.2 A (4 x 0.5A + 0.2A for the hub itself). Powering the hub from a molex is the easiest way, because the 5v rail of a molex is produced by PWM, not linear regul, so no watt wasted in heat.
    Add a relay to control the 5v line from a 12v fan header, and you'll be sure that all usb devices are off when pc is off.
    Phidget has 4-port hub powered from 12v, iirc.
  3. #13
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    Quote Originally Posted by DeltaFX
    A mobo's USB header only gives 500mA. That's enough for a passive HUB, but if you plan to use devices like usb-powered Zip250, or a hungry webcam, it may not work, cause these devices need all the 500mA.
    Sounds right to me, only thing I would add is to ensure you use an inline fuse to be on the safe side.
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
  4. #14
    Variable Bitrate nsmoller's Avatar
    Dec 2004
    NY
    if i want to power 2 usb hubs, could i use the 5v line or should i use the 12v... (or should i just get the f-ing 7 port hub )
    i need to power the hub and a full size dvd rom... i was thinking of making a make shift extension that plugs into a molex on the psu, the 5v wire goes to usb hub and the 12v goes to the dvd rom? they both should be grounded? which part of the 4 on the board needs to go to ground?
    [4Runna]
    next - wifi
  1. USB Hub does not show HD after cold boot
    By d_sellers1 in forum General Hardware Discussion
    Last Post: 04-05-2005, 01:46 PM
  2. USB soundcard through hub?
    By wizardPC in forum General Hardware Discussion
    Last Post: 12-01-2004, 01:03 PM
  3. Powering an unpowered USB hub?
    By Squiddy in forum Input Devices
    Last Post: 09-02-2004, 04:37 PM
  4. My experiences with various components...
    By Defiler in forum General Hardware Discussion
    Last Post: 01-27-2004, 01:49 PM
  5. Power for usb hub
    By bklynkaos in forum General Hardware Discussion
    Last Post: 01-24-2004, 05:45 PM
