Results 1 to 10 of 14
Thread: Power USB hub from psu
    Aug 2002
    Eau Claire, Wi
    I have seen that several people are powering USB hubs off the 5v line from thier psu. is there any beneift of doing this over a bus powered hub? Does running the hub right off the psu draw more power than a bus powered hub would?
    I have been looking for a 12v -> 5v adapter that can handle 2 amps for my hub, but cant find any. I might run it off my psu, but i dont want any unneeded draw on the psu.
    System: AMD Duron 1200+ , 512 MB ram , usb sb mp3+ , Tview 7" touchscreen , M1-ATX PSU , Slot Load iMac DVD-Rom , 40 GB laptop HDD, netgear USB 802.11g
    Progress: Installation: 90% Dash fabrication: 80%
    Parts Needed: USB GPS
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    Quote Originally Posted by meyer64
    It wont use any more power than running off the bus. You are best running it off the PSU and putting a suitable fuse in-line
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
    Aug 2002
    Eau Claire, Wi
    my hub is capable of being powered externally or by the bus. if the power is comming from the psu anyway, what difference does it make?
    Aug 2003
    Warwickshire, UK
    There is only a certain amount of current that you can draw from the bus.
    Dec 2004
    Miami, FL
    So does anyone know how to power a powered USB hub off a molex or some other line from the power supply rather than through the bus? I got a hub that can pull either from the bus or a power line and I'd prefer to use the power line because bus power sucks, I've already maxed it out using too many devices and I'm hoping drawing straight from the Opus rather than through the bus will help.
    Aug 2003
    Warwickshire, UK
    Quote Originally Posted by maxxell
    Yes what does it say is the power in (or what is the wall adapter voltage)
    Mar 2004
    Maryland/NOVA
    could i connect my usb hub to my ITPS?
    thanks.
    2001 Acura CL traded for a 2006 Subaru Legacy GT
    7" Lilliput Touchscreen
    NANO-ITX+m1-atx
    512 DDRsodimm
    60g SATA Laptop HD
    4x Apple DVDslot
    digimoto OBDii
    mS GPS
    mini BT keyboard
    relocated HU faceplate
    Dec 2004
    Miami, FL
    Quote Originally Posted by stevieg
    Couldn't tell ya. I'm on break so I'm not home. The box for the hub is home. Why does that matter, by the way?
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    if its not 5 or 12 volts, then your **** out of luck
    PC Components:
    My work log
    Mar 2004
    I was thinking about something similiar... I have M1-atx and one dc-dc psu (not using now) .. what about power usb hub from the second non cranking suitable ps?
  1. USB Hub does not show HD after cold boot
    By d_sellers1 in forum General Hardware Discussion
    Last Post: 04-05-2005, 02:46 PM
  2. USB soundcard through hub?
    By wizardPC in forum General Hardware Discussion
    Last Post: 12-01-2004, 02:03 PM
  3. Powering an unpowered USB hub?
    By Squiddy in forum Input Devices
    Last Post: 09-02-2004, 05:37 PM
  4. My experiences with various components...
    By Defiler in forum General Hardware Discussion
    Last Post: 01-27-2004, 02:49 PM
  5. Power for usb hub
    By bklynkaos in forum General Hardware Discussion
    Last Post: 01-24-2004, 06:45 PM
