Hooking up an itps is pretty easy, but be warned (as stated in multiple places on this forum) you can't used it with a 200w psu because the itps max's out at about 60w. I suppose if your drawingless than 60w from your 200w psu it'll be ok. Here's how to hookit up:
on one side of the itps you have the 3 power pins, the black is ground, (to the car chassis), the white goes to the cars 12v constant power ie always on, and the red goes to the car's switched acc on ie like the cig lighter. then on the other side of itps you have black and white power. these go directly to the psu.
not really hard at all. but be warned the itps has problems (or limitations) like the60w max, and the fact that you have like a 1.1v drop down so that usually when the engine is not on you don't get enough voltage to power the computer.
Well all these concerns have been discussed numerous times on these forums and you'll be abe to get more info
LinkBack URL
About LinkBacks
