Kevin, you could use our CarPC EZ or Pro Power Controller to control the PC, using the Remain-On option, allowing the PC to remain on for as long as you need. You can also make sure it turns off before the battery is discharged to a level it is damaged, or before it is completly dead, or still partially charged, or somewhere in-between, by using the adjustable shutdown voltages.
Driving for that long, the battery should charge back up fully, especially if you use our SDC to turn off the PC before the battery is completly discharged.
KyferEz
LinkBack URL
About LinkBacks
