Results 1 to 6 of 6
Thread: Leaving inverter turned on???
    Constant Bitrate KennyKen's Avatar
    England
    Hey guys
    Ive got my inverter but want to keep it in the boot with the actual PC where it will be connected to my 2nd battery.
    I was just wondering if i leave the inverter turned and the PC in Hibernate will the inverter draw alot of current and flatten the battery or will i be ok.
    Im using a 300w inverter by the way.
    Thanks for your help
    Ken
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Don't leave it on. I will drain you battery.
    (you could have found the answer to that by searching so next time.... )
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    I've left my 400 watt inverter on as long as 16 days with no draw.
    Maximum Bitrate TimmyM's Avatar
    Aug 2003
    Federal Way, WA
    my battery would be dead by morning.
    Constant Bitrate csnowman00's Avatar
    Feb 2005
    Wilkes-Barre, PA
    it all depends no the inverter, some models draw very little power when not being used...other draw just as much as a full load all the time when something is requiring ANY current...If this is your case, the power supply from the computer will require just a little to keep the mobo powered up, however the inverter still will draw alot of current.
    If your hibernating, why not just shut the inverter off? its not like your suspending it or anything, the computer is shutting off anyway
    Current Progress:
    [▓▓▓▓▓▓▓---]80%
    Final Assembly
    Ramline P3 PC
    10.4 inch Touchscreen
    Windows XP Embedded
    Road Runner
    http://www.projektnepa.com
    Electrical Engineer / Mobile DJ
  1. inverter startup prob~!
    By bulgogi777 in forum Power Supplies
    Last Post: 10-15-2005, 03:20 PM
  2. Replies: 6
    Last Post: 03-24-2005, 12:45 PM
  3. Problems with Xantrex inverter...
    By RoyN in forum Power Supplies
    Last Post: 11-16-2004, 07:26 PM
  4. Does inverter draw power when the computer is turned off?
    By phoTToniq in forum Power Supplies
    Last Post: 08-14-2003, 05:49 AM
  5. odd inverter behavior
    By jshrieve in forum General Hardware Discussion
    Last Post: 04-10-2001, 05:53 AM
