Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 38
Thread: BEST way to power up an HP E-PC???? HELP
  1. #11
    Nov 2003
    Marietta, GA
    How about a picture of the label on your laptop adapter...and its barrel plug.
    MikeH
  2. #12
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    I dont have that one anymore, I sold it when I switched to a shuttle and opus
    肚子笑痛了
    S60 Install
  3. #13
    Apr 2005
    eazyrog says that his inverter works fine. But, do you manually have to push the on/off switch on the PC itself? That stinks. I just purchased the e-pc 40 and installed Windows XP, but since it has the funky 8 pin power connection, I'm about to sell it since there's no easy solution to startup/shutdown. Not one that I can do myself anyway. Also, how does hybernate work? Can you just turn the inverter off, or do you have to "sign off" before? Thanks.
  4. #14
    Low Bitrate angusn's Avatar
    Mar 2005
    Connecticut
    e-PC options
    I've got a 40, and I've been looking at getting a 42 for the faster processor. I bought a spare power supply on eBay for $15 that I'll be hacking apart for a DC-DC power supply.
    I've read here that the older models like the one being talked about in this thread have a 19v barrel connector. Laptop cig-lighter adapters work with these as long as they handle enough amps. The best solution would be the CarNetix 1900 since it's made for this type of installation. Thats what I plan on using for my e-PC 40.
    I'd love to find a source for the power connectors cheeper than $15 for a whole power supply...
    Another reason for me using the CarNetix supply is that I'm switching to a mac mini eventually, and that's the perfect supply for it.
    Car: 1997 VW Passat TDI moving to
    1985 Mercedes-Benz 300D
    CPU: HP ePC 1gig/256meg/250 gig
    Status: Ghetto Install w/Inverter,
    Xenarc & GPS & RadioShark
    ToGo: DC-to-DC conversion, Grease conversion
  5. #15
    Constant Bitrate chuckctv's Avatar
    Aug 2004
    Virginia
    guys guys guys.... i do mostly ask for help usualy, but in this case i am fully capable of solving the power problem. I too have the same unit (p3-933, 256m,20gig,ect).
    yes the power supply unit is a 19v plug it is rated for very low power only uses about 1.5 amps (ive checked with meter). I just bought a dc-dc power supply for a laptop (most never laptops are between 18.5-20v), i found the compaq 3000series (vehicle adapter) is 19volts at 3.5 amps. just get that and your done. cut off the cig-plug and striaght wire. also i just hit the power button which i setup for suspend mode (u could setup for hibernation mode).
    BOOM!!! thats it, quick, clean and cheap (well if u buy on ebay used its cheap new its like 99 bucks), but on ebay i got mine for 30bucks..
    Chuck
    www.XionElectronics.com
    **MY NEW STORE** Come Visit
  6. #16
    The Lavender Tie Just
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    Quote Originally Posted by angusn
    Can't you just upgrade the processor? On that note, are there any Socket 370 Pentium M's for less power consumption?
    Sorry for the thread jack.
    Peace,
    Rafster
  7. #17
    Apr 2005
    Ive got the same piece hiere, i just got one problem. This one wont power up from power button at all, its dead. Broken sumwhere from the mobo :/ Is there any other ways to power up this computer ? I Know it works, its just the damn power button :/
  8. #18
    Sep 2006
    Chitown
    open up the machine and use a screwdriver across the pins that the power button connects to. hope that makes sense.
  9. #19
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    Quote Originally Posted by AllShowNoGo View Post
    WOW... More than a year old....
    Peace,
    Rafster
  10. #20
    FLAC FC3S's Avatar
    Jul 2006
    Seoul, Korea
    Quote Originally Posted by Rafster View Post
    Peace,
    Rafster
    thats the best part of resurrecting a dead thread,
  1. Car power supply (battery charger) from old pc supply
    By stimps in forum Power Supplies
    Last Post: 08-20-2010, 01:39 AM
  2. PC power off after playing Divx
    By hakira007 in forum General MP3Car Discussion
    Last Post: 03-03-2005, 10:54 AM
  3. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
  4. Can't power LCD and PC at same time?
    By SBDJ in forum Power Supplies
    Last Post: 11-10-2004, 09:06 PM
  5. remote turn on lead from headunit to power up PC
    By BluCivic93 in forum General Hardware Discussion
    Last Post: 07-27-2000, 03:13 PM
