Page 4 of 4 FirstFirst 1234
Results 31 to 38 of 38
Thread: BEST way to power up an HP E-PC???? HELP
  1. #31
    Variable Bitrate billmee's Avatar
    May 2005
    USA
    This worked for my BIOS;
    Unplug both mouse and keyboard.
    Wait for the bios error.
    Plug in a working keyboard and acknowlegde the error F4 I think.
    Now your missing keyoard/mouse will not generate a bios error.
  2. #32
    Apr 2006
    Quote Originally Posted by chuckctv View Post
    guys guys guys.... i do mostly ask for help usualy, but in this case i am fully capable of solving the power problem. I too have the same unit (p3-933, 256m,20gig,ect).
    yes the power supply unit is a 19v plug it is rated for very low power only uses about 1.5 amps (ive checked with meter). I just bought a dc-dc power supply for a laptop (most never laptops are between 18.5-20v), i found the compaq 3000series (vehicle adapter) is 19volts at 3.5 amps. just get that and your done. cut off the cig-plug and striaght wire. also i just hit the power button which i setup for suspend mode (u could setup for hibernation mode).
    BOOM!!! thats it, quick, clean and cheap (well if u buy on ebay used its cheap new its like 99 bucks), but on ebay i got mine for 30bucks..
    Chuck
    Sorry guys if this question has been asked a thousand times before. I too have the same unit as Chuck with the single pin 19V power supply.
    When you say a vehicle power supply do you mean one that has the cigrette lighter fitting on the end or a standard PSU?
    Do you have model numbers for these?
    Once I can get the system powered up I can then install the windows software.
    Apr 2006
    E pc power up option
    I have found this car pc laptop power supply advertised on ebay.
    Will this work on the older model of the e pc with the 19V single pin power connector?
    Is that all I need and i'm away?
    http://cgi.ebay.co.uk/Universal-Lapt...QQcmdZViewItem
    May 2005
    USA
    Quote Originally Posted by phantome46 View Post
    Yeah I think so.
    If I were you though I'd get a carnetix cnx-p1900.
    You get 10x more features for 3x more $$$...
    You should look at this thread, you might not need a dc-dc afterall
    search the forum for
    HP e-PC great solution for my 02 BMw
  5. #35
    Apr 2006
    I am not able to find the post for the BMW project? can you send the link?
    thanks
  6. #36
    Apr 2006
    thanks
  7. #37
    Sep 2006
    Chitown
    i wasnt easy but i found it.
    BMW Project
    HP eVectra thread
    HP eVectra Power Questions
    The Bimmer thread also includes info on changing the BIOS splash screen
    1997 Grand Prix GTP - Pioneer Premier HU - Alpine 4ch for mids/highs - McIntosh separates in the rear (soon to be in front as well) - Custom Passive Xovers - Pioneer Class A 300wrms amp - 2.5 farad cap - The original RF "The Punch" Pro Series 12"
  8. #38
    Oct 2007
    Powering the E PC
    Hello to All. I am new to this site but have been an avid reader (of this site) for a while. I recently purchased an E PC for a carpc. I didn't research here first, though. At first I thought there would be a problem powering down and then restarting the epc because there aren't any dc-dc psu's (that I have found) that will work with it. But alas, all was not lost. I invested in an APC UPS and found my solution. The UPS will be powered through an inverter and will shut down (hibernate) my system 1 minute after it switches to battery (ie when I turn my car off.) Upon restarting the car power is returned and my system returns to the last state. This by far has been the simplest solution I have found. I'm sure there are several other ways out there. I hope this helps somebody. If there are any other, better solutions feel free to let me know. Thanx.
  1. Car power supply (battery charger) from old pc supply
    By stimps in forum Power Supplies
    Last Post: 08-20-2010, 12:39 AM
  2. PC power off after playing Divx
    By hakira007 in forum General MP3Car Discussion
    Last Post: 03-03-2005, 09:54 AM
  3. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 12:13 PM
  4. Can't power LCD and PC at same time?
    By SBDJ in forum Power Supplies
    Last Post: 11-10-2004, 08:06 PM
  5. remote turn on lead from headunit to power up PC
    By BluCivic93 in forum General Hardware Discussion
    Last Post: 07-27-2000, 02:13 PM
