Results 1 to 3 of 3
Thread: 150w PC 300w Power inverter... help?? Please..
    Dec 2003
    Hi.
    I have a dell Optiplex pc (600mhz P3)
    It has a 150w PSU in it and it is all ready to go in my car.
    I am aiming to power it of a 300w inverter, as it seemed more than enough considering the PSU is only 150w.
    I have plugged the pc in and the inverter. When i turn the inverter on i get a continuous clicking noise from the inverter and the PSU in the PC.
    The PC will not power up and it will keep clicking until i turn the inverter off or unplug the power cable from the pc.
    The inverter does work as i have used it to power household sub speaker to test it with.
    Has anyone got any ideas on what the problem is??
    Chris
    Maximum Bitrate neon_eddy's Avatar
    Nov 2004
    Ham Lake, MN
    does the dell power up in your house.. I know it's an obvious question..
    if it does.. then it's quite simple. it's an issue with the inverter.. 300W should be good enough .. I ran a full PC of of 300W once.. 15" screen and all .. of course you had to turn on the PC first.. wait a minute and then turn on the screen.. much like they had to do in apollo 13 :-)..
    anyway .. I recommend dc-dc anyway.. you get nice shutdown controllers and battery rundown protection ..
    Shawn
    Check out my web company Minneapolis Web Designer | MODx Web Design - Himmelberger Design
    Dec 2003
    yeh, the pc powers up in the house, used it to install all software and stuff.
    But it confused me a little because the inverter has powered other equipment.
    I cant really afford the DC to DC stuff, was trying to do it on the cheap.
    But if the inverter has to be sent back then i mite as well.
    How much is the DC to DC stuff?
    Chris
  1. Car PC EZ 2.4 SDC/Inverter Controller - NOW Avail!
    By hd54321 in forum Power Supplies
    Last Post: 02-24-2005, 01:42 PM
  2. Can't power LCD and PC at same time?
    By SBDJ in forum Power Supplies
    Last Post: 11-10-2004, 09:06 PM
  3. Replies: 4
    Last Post: 10-29-2004, 09:10 AM
  4. Replies: 5
    Last Post: 06-16-2004, 01:41 PM
  5. Have to switch inverter off and on to power up pc
    By mbowler in forum General Hardware Discussion
    Last Post: 08-22-2000, 12:00 AM
