Page 11 of 11 FirstFirst ... 234567891011
Results 101 to 108 of 108
Thread: DSX12V: 12V in 12V out 10 AMPS!
  1. #101
    Registered User
    May 2003
    Quote Originally Posted by MrPerfectionest
    It was me who posted to the newsgroup about this product.
    Yeah I saw that thread MrP
  2. #102
    Apr 2001
    Portland OR
    You have a nice supply there, really nice. You should have trusted me (not an easy thing to do though) when I said I was just curious. Now someone who is even more up to terms on these things went and exposed your supply. Why don't you offer a full psu? High power on the 5V line is 'trivial' and I am sure tons of people would be happy with just the supply and not all the shutdown features and extras the opus provides.
    It was a matter of time before the data was going to get out. I was under NDA from the vendor.
    I am working on a 220 watt ATX psu.
    -Jeff
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
  3. #103
    Apr 2001
    Portland OR
    Quote Originally Posted by Blop
    I have read the whole thread and viewed the pdfs....but im stupid so im going to ask a question!
    How do i power an atx motherboard with this? I dont see anything i can connect to a atx power socket on my mainboard.
    Im prepared to be flamed
    Thanks!
    Most any casetronic case, or morex case will have a DC-DC converter that has an ATX connector on it. It will take in 12 volts. It will say the tollerance on this 12 volts is 10% that is a lot less headroom than you'll find in a car (8-16). You use the DSX12V to give you clean 12 for other applications.
    -Jeff
    www.mpegbox.com
  4. #104
    Constant Bitrate old_lou's Avatar
    Oct 2004
    UK Midlands
    Thanks!
    You don't what Zoot has is a clean 12 regulated supply from a fluxuating power supply (the car) this is then used to feed the 12v-to atx psu that is found in many small pc cases mainly built to hold Epia motherboards that have a small form factor. Be aware that some full size motherboards are not compatable with this 12v-to atx style supply. I tried a Serentini case with a Mercury motherboard and found that the 12v-200w to atx was not compatable and the board would only work with the small genuine mains atx supply provided with the case so I then purchased an Epia 1000 board which did work.
    EPIA MII: 512m Ram: LinITX 8" Touch Screen: Carnetix P1290 PSU: 802b PCMCIA Wireless card: Slot DVD Player: Touchpad: Wireless Keyboard: BU303 GPS Mouse:
    Win 2000: RoadRunner Front End: Michelin Mapstore GPS: Netstumbler:
  5. #105
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    How can one use it for boosting the opus capacity?
    Should I override the opus' 12v by hacking the atx cable? or can I put the 12v output in parallel? I guess I just need to find what cables in the atx connector (and molex conns) are 12v and override them with the DSX, or put them in parallel? How big is it? It wont fit inside the opus case, will it? (for those with an opus)
    When can I order 2 units?
    PS: how does that mobo power pefierals? does it do 5v conversion on board? or is it just the board that is 12v only? Thanks!
  6. #106
    Registered User
    May 2003
    pefierals?
  7. #107
    São Paulo, Brazil
    talkin to me? no, I need it for the mobo...
  8. #108
    Registered User
    May 2003
    Quote Originally Posted by RoyN
    LOL yeah, does that meant peripherals?
    Just a funky spelling mistake you made there, if im thinking right
  1. 12v for LCD?
    By MikeHunt79 in forum Power Supplies
    Last Post: 03-29-2005, 01:47 AM
  2. 12V line power requirements
    By rushnrockt in forum Power Supplies
    Last Post: 03-08-2005, 02:02 AM
  3. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:31 PM
  4. 120V to 12V adaptor how many amps needed?
    By nevide in forum Power Supplies
    Last Post: 12-23-2003, 08:46 AM
  5. Will this work? DC-DC 12v input, 12v output 8 amps!
    By nullity in forum Power Supplies
    Last Post: 08-02-2002, 02:49 AM
