Page 2 of 11 FirstFirst 1234567891011 LastLast
Results 11 to 20 of 108
Thread: DSX12V: 12V in 12V out 10 AMPS!
  1. #11
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    Quote Originally Posted by zootjeff
    What is a POL module? How do most people use the 5 volts in this application?
    See above.
    Putting the regulation at the point of the load assures that the proper voltages are delivered to peripherals without the significant voltage drop associated with long runs or the need to use large guage wire to avoid those same drops.
    5V is the name of the game for most peripherals. Simple buck regulators that can output 2-3A would work for nearly all peripherals. A larger 5-10A supply might be more appropriate for a group of co-located devices. Proper sequencing of the power may be required for some applications to work properly but I think it's less of an issue than with what I was talking about before with the 12V supply and the M1-ATX.
  2. #12
    Variable Bitrate therussman2002's Avatar
    Mar 2004
    Milwaukee, WI
    gosh im about to solder fifteen 12v, 2amp max regulators together to make a 30amp 12v regulator for my pw200... perhaps if i fail or become too lazy i can pick a couple of these up
  3. #13
    Constant Bitrate HoSS's Avatar
    Dec 2004
    Quote Originally Posted by therussman2002
    You are joking right?..... I hope your joking.....
  4. #14
    Variable Bitrate rubicon's Avatar
    Feb 2005
    $240 worth of puddin'
    Or, you could use one 12v regulator and 2-3 beefy pass transistors. But hey, its your project.
  5. #15
    That's exactly what I did. I'm installing it in the car today. But I would have bought this had it been available at $50. Now if you want to combine it with your $42 shutdown controller and sell it to me at $70 I'll still bite . I'm a good beta tester!
  6. #16
    Mar 2004
    Milwaukee, WI
    Quote Originally Posted by rubicon
    eh i never heard of these pass transistors, or beefy ones for that matter... cant say im much of an electronics genious
    if you care to elaborate, perhaps i can simplify my project...
    when would this dsx12v for $50 be available?
  7. #17
    Apr 2001
    Portland OR
    Probably after enough people buy it at 70 and I'm able to get the volume up!
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
  8. #18
    Chances are you would have to add some kind of load balancing circuit for that which will up the cost and complexity. I got away without any of that with 13 of the 2A regulators and 6 capacitors. Running in my car now . But it definitely won't work below about 11V .
  9. #19
    Mar 2004
    Milwaukee, WI
    wups, i thought it was 50... so are the $70 editions available now then?
  10. #20
    Feb 2005
    Take a look at this: Increasing Regulator Current
    Planning on building one myself.
    Than Radioshack 2N3055 can be substituted for the "TIP2955" specified in the circuit.
  1. 12v for LCD?
    By MikeHunt79 in forum Power Supplies
    Last Post: 03-29-2005, 12:47 AM
  2. 12V line power requirements
    By rushnrockt in forum Power Supplies
    Last Post: 03-08-2005, 01:02 AM
  3. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 09:31 PM
  4. 120V to 12V adaptor how many amps needed?
    By nevide in forum Power Supplies
    Last Post: 12-23-2003, 07:46 AM
  5. Will this work? DC-DC 12v input, 12v output 8 amps!
    By nullity in forum Power Supplies
    Last Post: 08-02-2002, 01:49 AM
