Page 6 of 11 FirstFirst 1234567891011 LastLast
Results 51 to 60 of 108
Thread: DSX12V: 12V in 12V out 10 AMPS!
  1. #51
    Apr 2001
    Portland OR
    Quote Originally Posted by therussman2002
    i would preorder one right now if you could assure me this will be adequate for a pw-200v 200watt (250peak) power supply connected to a p4 2.8 processor...
    I allready told you the numbers don't jive. I even provided screenshots of the car cranking and proof that it only works up to a 15 amp load. That is only 180 watts peak. So, I obviously can't do that.
    The PW200 is not a 200 watt power supply. It is a cable with a 80 watt power supply for the +5 and +3. They do nothing on the 12 volts. The 18 gauge wire that it comes with, there's no way you'll even get 200 watts through it. That is marketing false advertising.
    -Jeff
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
  2. #52
    Variable Bitrate therussman2002's Avatar
    Mar 2004
    Milwaukee, WI
    ah i am beginning to understand now... guess i've been had, or i dont read into things enough... probably the latter
    sounds like i've wasted enough money on all the wrong stuff, perhaps i should roll with that key power psu and be done with this silliness
  3. #53
    Full bridge topology?
  4. #54
    Apr 2001
    Portland OR
    Quote Originally Posted by MrPerfectionest
    Something like that.
    www.mpegbox.com
  5. #55
    Quote Originally Posted by zootjeff
    Given the length of the wire, it should still work I would have thought - the wires might just get a bit warm. Luckily my setup is only driving about 84W peak so I don't have to find out the hard way.
    im really lazy and i dont feel like hooking up 15 regulators together, only to have it probably blow up in my glove box and fry my $400+ setup
    Mines still going strong. Trying to decide whether to buy zootjeff's shutdown controller or roll my own - or live without one (I'll definitely be doing this for a bit ). I think I've decided against getting one of his new regulators since I don't actually need one.
  6. #56
    Nov 2004
    Cali
    He is very secretive Trying to hide industrial secrets
    I have found you an argument; I am not obliged to find you an understanding.
  7. #57
    Apr 2001
    Portland OR
    Quote Originally Posted by rushnrockt
    Just trying to protect my investment. I've put a lot of time and money into it. And I think I've come up with a really great product.
    www.mpegbox.com
  8. #58
    You sure have - the best of luck selling it. I think it'll be a real hit. I'm hoping so - I'm going to wait until it drops due to volume so I can pick it up cheap.
  9. #59
    Nov 2004
    Cali
    I totally understand, I am just teasing.
  10. #60
    He could add a $10 7.2Ah sealed lead acid battery as a tank circuit. That's how I'm surviving crank with my linear 12V DC regulator circuit. I finally have it all hooked up in the car and the PC survives multiple cranks just fine . That would be a cheap extension to your circuit. Of course - I'm only drawing 7A and the voltage starts to drop pretty rapidly so I'm not sure what it would do with a higher current. It might survive crank but it probably wouldn't survive long after the car is turned off (in my case that disconnects the ACC line I'm using for power when the car is running) even if the PC was connected straight to the battery.
  1. 12v for LCD?
    By MikeHunt79 in forum Power Supplies
    Last Post: 03-29-2005, 12:47 AM
  2. 12V line power requirements
    By rushnrockt in forum Power Supplies
    Last Post: 03-08-2005, 01:02 AM
  3. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 09:31 PM
  4. 120V to 12V adaptor how many amps needed?
    By nevide in forum Power Supplies
    Last Post: 12-23-2003, 07:46 AM
  5. Will this work? DC-DC 12v input, 12v output 8 amps!
    By nullity in forum Power Supplies
    Last Post: 08-02-2002, 01:49 AM
