Page 7 of 11 FirstFirst 1234567891011 LastLast
Results 61 to 70 of 108
Thread: DSX12V: 12V in 12V out 10 AMPS!
  1. #61
    Apr 2001
    Portland OR
    Quote Originally Posted by Arathranar
    He could add a $10 7.2Ah
    Right you are. He probably doesn't even need the 200watts anyway.
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
  2. #62
    Nov 2004
    Cali
    Quote Originally Posted by zootjeff
    What if he needs to run a server farm?
    I have found you an argument; I am not obliged to find you an understanding.
  3. #63
    Eek
    Eek is offline
    Newbie Eek's Avatar
    Feb 2005
    Hi Jeff,
    How high is the efficiency at smaller load conditions? ~0.5 Amp or less. What is the no load current draw?
    Will any input or output filtering be required to reduce EMI or RFI, or is this a non-issue?
    Thanks!
    TBD
  4. #64
    Quote Originally Posted by rushnrockt
    Then he needs to get together with the guy wanting to put a P4-2.8 with top of the range video and a raid system in his car and they can keep warm together .
  5. #65
    Apr 2001
    Portland OR
    Quote Originally Posted by Eek
    Hi Jeff,
    Thanks!
    The "off current" is about 100 microamps.
    The no load current is between 15-50 mA depending on wether the voltage is under over.
    www.mpegbox.com
  6. #66
    have you measured output ripple?
  7. #67
    Apr 2001
    Portland OR
    Quote Originally Posted by MrPerfectionest
    Yes it is under 60 mV at a 10 amp load
    www.mpegbox.com
  8. #68
    And it can do that ripple over the full specified voltage range and load condition? In particular, at the lowest Vin you specify and a 10A load does the output ripple stay below 120mV?
    I decided its probably a SEPIC configuration now
  9. #69
    Apr 2001
    Portland OR
    From 8-16 volts the ripple stays below 100mV It is worst with an 8v input.
    www.mpegbox.com
  10. #70
    Mar 2005
    kansas
    Im the guy that wants the 2.8 ghz and the 9600 pro is a crap video card compared to a pci express type. I bet if i said i wanted a pci express vid card you would have **** yourself. And the raid aray would be icing on the cake.
    And what the **** is the point of a carpc if it cant be everything your desktop is? At least im not trying to vapor cool my carpc. Although that would be awsome.
    And isnt the point of this forum to push the envelope of what can be done and not just follow what everyone else does? I guess i could be like you and settle for less. Hell i may as well quit my job have 5 kids and live off welfare in a trailer with a fat *** wife. Thanks for the new direction in life. DICK
  1. 12v for LCD?
    By MikeHunt79 in forum Power Supplies
    Last Post: 03-29-2005, 12:47 AM
  2. 12V line power requirements
    By rushnrockt in forum Power Supplies
    Last Post: 03-08-2005, 01:02 AM
  3. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 09:31 PM
  4. 120V to 12V adaptor how many amps needed?
    By nevide in forum Power Supplies
    Last Post: 12-23-2003, 07:46 AM
  5. Will this work? DC-DC 12v input, 12v output 8 amps!
    By nullity in forum Power Supplies
    Last Post: 08-02-2002, 01:49 AM
