Page 1 of 11 12345678910 ... LastLast
Results 1 to 10 of 108
Thread: DSX12V: 12V in 12V out 10 AMPS!
    Apr 2001
    Portland OR
    Hi all:
    I just got done designing a new DC-DC power supply that takes in 6-20 volts and puts out 12V on the output. With the output between 10-16 volts the output load can be 10 amps sustained, 13 amps peak. It is optimized for car use and will survive cranking no problem with a 10 amp load.
    It measures 1.9" by 3.5" by 1.2" and has 4 standard 0.25 inch automotive faston connectors.
    There is a power on LED and a On/Off Jumper.
    It can be ordered as a fixed output supply, or as a supply with an output range adjustable by a small pot.
    Sounds too good to be true? It's real. I even surprised myself when I measured my first sample and I measured 97.5% efficiency with a 85-watt load!
    The supply is 95+ percent efficient over the 8-15 volt range.
    Lookout. The DSX12V is pretty nice.
    -Jeff
    http://www.mpegbox.net/DSX12V/DSX12V_2.jpg
    http://www.mpegbox.net/DSX12V/DSX12V_top.jpg
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
    Nov 2004
    Cali
    I must be blind or stupid after midnight, is there such a thing as pricing info or more technical info? I'd be very interested
    I have found you an argument; I am not obliged to find you an understanding.
    Apr 2001
    Portland OR
    Quote Originally Posted by rushnrockt
    Pricing is going to be somewhere around 50-80 dollars. I don't know all the manufacturing costs yet. Also, mp3car store might pick it up.
    www.mpegbox.com
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    Wow, if you can hit the lower end of that price range, this combined with an M1-ATX would make a sweet cost effective combo for the higher powered AMD/P4 boards out there (assuming the power sequencing can be done right).
    Nov 2004
    Cali
    Quote Originally Posted by zootjeff
    Just wondering if there is such a thing as component list for your little design I am not going to compete with you promise!
    I am just figuring out all my options for senior project that is due in *gulp* 12 weeks. Thanks.
    Registered User
    May 2003
    Very nice jeff.
    Competition is heating up
    Apr 2001
    Portland OR
    Quote Originally Posted by rando
    Yaa, you can totally connect the PS_ON of the ATX connector to the PS_ON of this power supply and you'll get 12 volts at tons of amps for the VRM of a P4 Motherboard. Thats a nice application!
    I'm also thinking of other applications for it. It would make a good laptop adaptor too. I can adjust it to put out say 15 volts for example.
    www.mpegbox.com
    Mar 2004
    Redondo Beach, CA
    If you produce a 5V POL module also, you'd pretty much have all bases covered.
    Apr 2001
    Portland OR
    What is a POL module? How do most people use the 5 volts in this application?
    www.mpegbox.com
    Aug 1999
    Washington D.C.
    Point of load.
  1. 12v for LCD?
    By MikeHunt79 in forum Power Supplies
    Last Post: 03-29-2005, 01:47 AM
  2. 12V line power requirements
    By rushnrockt in forum Power Supplies
    Last Post: 03-08-2005, 02:02 AM
  3. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:31 PM
  4. 120V to 12V adaptor how many amps needed?
    By nevide in forum Power Supplies
    Last Post: 12-23-2003, 08:46 AM
  5. Will this work? DC-DC 12v input, 12v output 8 amps!
    By nullity in forum Power Supplies
    Last Post: 08-02-2002, 02:49 AM
