Results 1 to 3 of 3
Thread: Wiring - EQ,opus,4ch amp,subs,lcd-drawing idea
    Newbie Warpath's Avatar
    Jan 2005
    West Virginia
    Hello all. I came across an EQ today that I thought would work great with my next install. The EQ has RCA outs and a sub out. Also has a fader knob and Aux input....and its only $30. I was thinking of ditching my head unit and have this mounted under the LCD. Front and Rear RCA's from the EQ would run into a 4CH amp. The Sub RCA's would run into the amp for the subs. The fader knob on it will allow me to fade from front to rear without messing with the amps. Have a graphic EQ will also be easy to tweak sound. The line-out of the carputer will go into the aux-in on the EQ. Here is the EQ I was looking at using.
    Here is a drawing of how I was thinking to wire it all up. Any suggestions would be great.
    Current Progress
    Fujitsu Stylistic 3400 TabletPC
    Wireless Keyboard
    300w Inverter
    40gig External USB Hard Drive
    FM Modulator
    My Carputer
    Raw Wave EsKALad's Avatar
    Jan 2005
    Chicago, IL
    it looks like a good setup...however ive heard you should ground everything to ONE spot to reduce noise..maybe that will help you in the future.
    Sep 2006
    Rutherfordton, NC
    I'm looking to do something similar. Keep us updated!
  1. 2 Screen Mount Idea - Drawing Inside
    By Demolition Man in forum LCD/Display
    Last Post: 08-10-2007, 09:57 AM
  2. Security idea - hide the HU
    By jaeger in forum General MP3Car Discussion
    Last Post: 08-23-2004, 12:17 PM
  3. Specific wiring schematic 4 Optrex DMC40457?
    By sooty in forum LCD/Display
    Last Post: 07-17-2001, 02:11 AM
