Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 51
Thread: Poll: What PSU Setup are you using
  1. #11
    Nov 2004
    Northern VA
    Epia 10k
    M1-atx
  2. #12
    $20 lawn tractor battery isolated by a $5 30A relay powering a $39 400W inverter which powers a free 120 watt computer power supply. Works great, immune to crank, cheap, it wont drain the main battery if the computer stays on too long, it's nice to have a 110V outlet in the dash, and when I want to work on the carputer in the garage I just unplug it from the inverter and plug it into an extension cord. Now I know this setup is inefficient and that troubled me very badly. I crunched all the numbers and this gross inefficiency affected my gas mileage! My actual miles per gallon went down by .000173% or in actual distance, a whole three quarters of an inch! I can live with that.
  3. #13
    Maximum Bitrate Zebelkhan's Avatar
    Dec 2004
    Bay Area, CA
    Quote Originally Posted by turbochris
    ...this gross inefficiency affected my gas mileage! My actual miles per gallon went down by .000173% or in actual distance, a whole three quarters of an inch!
    Shame on you...
    Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
  4. #14
    Newbie Stray's Avatar
    Feb 2005
    Belgium
    And again:
    Epia M10000
    M1-ATX
    Stage 1:[||||||||||||||||||||] 100%
    Epia M10000, Lilliput 7' TS (modded), Teac DV28-SL, Globalsat BU-303, Maxtor 40GB 7200rpm, 512 MB pc3200, M1-ATX, Kenwood KDC-W6527SE
  5. #15
    Maximum Bitrate eCar™'s Avatar
    May 2003
    SE Michigan
    Wow, that is some horrible gas mileage you are getting, if .000173% is equal to 3/4".
  6. #16
    Variable Bitrate egeekial's Avatar
    May 2004
    FV24
    Opus 150
    (see the signature)
  7. #17
    I must have missed a decimal point somewhere
  8. #18
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    im using the one that came with my pc :-D
  9. #19
    Variable Bitrate Curly_cat's Avatar
    Jun 2004
    Ipswich, UK
    VIA Epia MII12000
    DC-DC Board in the Cubid 3688 Case
    Carnetix CNX-P1260
    : Jetway J7F2 1.5Ghz Mainboard : Cubid 3688 : CarNetix CNX-P1260 :
    : Netgear 802.11g PCMCIA : 2 x LinITX 7" Screens :
    : BU353 USB GPS Mouse : Panasonic UJ845 DVDRW :
  10. #20
    cdm
    cdm is offline
    Nov 2003
    atlanta ga
    inverter, 70watt PSU that came with the case. Works just fine but it won't survive crank so i put in a UPS and that takes care of it..
  1. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 07:25 PM
  2. Best PSU for my setup
    By themolt in forum Power Supplies
    Last Post: 03-20-2005, 06:16 PM
  3. PSU for my new setup
    By djXternal in forum Power Supplies
    Last Post: 03-07-2005, 03:41 PM
  4. Battery to PSU setup
    By weazelb0y in forum Power Supplies
    Last Post: 01-15-2004, 08:05 PM
  5. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 02:07 AM
