Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 51
Thread: Poll: What PSU Setup are you using
  1. #21
    Mar 2005
    UPS - damn that makes allot of sense CDM
    Looks like I'm going to buy the smallest UPS that I can find that will survive a 2 second crank. Looks nicer and is a nicer looking solution.
    Yeah I know a tank circuit is basically an DC-DC ups solution. Makes sense. The only pre-made tank circuit that I've seen though has to have many inputs and outputs, doesn't look very nice (doesn't come in a box or anything - looks like a big transistor with a huge heatsink mounted on a PCB) and won't accept anything lower than 8 AWG power wire realistically. I also wonder what kind of load a tank circuit could handle?
    Chaintech 7NIL Amd Socket A - Sempron 2600+
    Ultra Low Profile IN-Win black microATX case (only 3.5" tall!)
    Vector 400W Power Invertor
    some small UPS - not sure which one yet....
    -LAKORAI
  2. #22
    Variable Bitrate kmcniece's Avatar
    Aug 2004
    Portland, Oregon
    M10000
    Opus 90W
    I hope.....
    Haven't tested the incar setup yet.... hopefully soon.
    EPIA M10000, 512 Ram, Opus 90, GPS, XM, 7" Xenarc, Pioneer HU
    Status:
    Installed & Working....
    Custom enclosures
    Newbie Guide
  3. #23
    Newbie trimpy's Avatar
    Mar 2005
    Grand Rapids, MI
    CarNetix 1280 Regulator
    EPIA TC10000 w/ onboard DC/DC converter
    2003 VW Jetta Wagon 1.9L TDI 5 speed
    <|||-------> 35% ish
    CarNetix P1280 80w
    EPIA TC10000 Mobo, 512MB SODIMM DDR, 160GB HD, Orinoco 802.11b, Hollux GPS (USB), 12dBi Omni Antenna
    Waiting on:
    DWW-700M 7" 1-DIN Display :-D (2 weeks maybe!)
  4. #24
    Raw Wave EsKALad's Avatar
    Jan 2005
    Chicago, IL
    via mini itx p4 with 1.7 mobile p4 chip
    opus 150 watt
  5. #25
    Quote Originally Posted by turbochris
    I must have missed a decimal point somewhere
    My calculations put you at 6.8 mpg. That is betty bad!
  6. #26
    Soyo K7-VME micro atx m/b
    AMD 2500+ underclocked to 1900+
    PW-200 200W psu - $50
    7.2Ah sealed lead acid battery tank circuit - $10
    13 x 2A, 12V linear DC-DC regulator chips in parallel - ~$30
  7. #27
    Feb 2005
    VIA MII-12000 powered by a PW-200 with ITPS power sequencer
  8. #28
    Feb 2005
    monster 300 watt clean power inverter
  9. #29
    Oct 1999
    London England
    crappy pcchips motherboard and p3 600
    was using modded sproggy 2.7 with some features from version 3 namely the max1771 chips to give more on the 12v
    Now finishing a mk4.1 psu which will replace old psu
    b4 that bacj in 1999/2000 used 300watt inverter
  10. #30
    Maximum Bitrate Vchat20's Avatar
    Jan 2005
    Warren, Ohio, USA
    although i havent built mine yet, the plan is simply to go with an inverter and a standard PSU. but now that i have finally been able to find the power rating on this thing (PSU says 160W max), i may end up going the 150w opus route if it fits the budget.
    Your everyday carpc geek and tech guru at your service. *bow*
  1. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 07:25 PM
  2. Best PSU for my setup
    By themolt in forum Power Supplies
    Last Post: 03-20-2005, 06:16 PM
  3. PSU for my new setup
    By djXternal in forum Power Supplies
    Last Post: 03-07-2005, 03:41 PM
  4. Battery to PSU setup
    By weazelb0y in forum Power Supplies
    Last Post: 01-15-2004, 08:05 PM
  5. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 02:07 AM
