Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 51
Thread: Poll: What PSU Setup are you using
  1. #31
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    P3 800 mATX
    Hammy the Hamster in his excercise wheel hooked up to a dynamo with an auxillary motor for when he gets tired.
  2. #32
    Mar 2005
    Epia M10k
    Opus 90W
  3. #33
    Maximum Bitrate Vchat20's Avatar
    Jan 2005
    Warren, Ohio, USA
    i just have to ask a quick question on the subject. seeing as my PSU states 160W max, anyone think id be able to get away with a 150W opus?
    Your everyday carpc geek and tech guru at your service. *bow*
  4. #34
    Mar 2002
    Tucson
    The rating on your supply is a max rating the supply will deliver, not what your system will draw. You need to calculate amount of power your system will require, and see if it is less the 150 watts. If your system was running fine with a 160 Watt supply, then 150 Watts will probably be okay. Most engineers allow more than a 10 percent design margin in there products. I suspect that your system draws much less then 160 Watts.
    The supply I use is my own design with linear regulators configured as switch mode controllers. Probably the same effeciency as an Inverter/AC supply setup, but it survives engine cranking with no tank circuit or UPS.
    Walt
  5. #35
    FLAC -zip-'s Avatar
    Ontario/Canada
    Epia MII 10000
    Opus 150
    Sound Stage
    Eclipse|MTX|Infinity
  6. #36
    Constant Bitrate Paul C's Avatar
    May 2004
    West Sussex
    Epia M1000
    modified sproggy 2.5
  7. #37
    Maximum Bitrate PORTUGAL's Avatar
    Oct 2003
    PORTO
    EPIA M1000
    -Opus 150
    Here in Portugal we have great weather, lots of brunnets, party a lot,drink a lot....
    http://img138.echo.cx/img138/896/bannerjoshua5dy.jpg
  8. #38
    Mar 2005
    Sportsvan
    250W DC ATX PFC Power Supply (9-18VDC)
    MSI 865pe neo2-v class
    P4 3,06 HT 800 fsb
    1024 ddr 400mhz dual
  9. #39
    Constant Bitrate pate60's Avatar
    Jun 2004
    Auckland, New Zealand.
    M10K
    Morex 60w DC-ATX
  10. #40
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Epia M10k
    PW70a DC-DC PSU
    Carnetix 1260 regulator startup/shutdown
    Want to:
  1. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 07:25 PM
  2. Best PSU for my setup
    By themolt in forum Power Supplies
    Last Post: 03-20-2005, 06:16 PM
  3. PSU for my new setup
    By djXternal in forum Power Supplies
    Last Post: 03-07-2005, 03:41 PM
  4. Battery to PSU setup
    By weazelb0y in forum Power Supplies
    Last Post: 01-15-2004, 08:05 PM
  5. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 02:07 AM
