Results 1 to 6 of 6
Thread: Will this work? inverter help
    Low Bitrate Bullwinkle777's Avatar
    Mar 2005
    Waynesville, Ohio
    I was woundering if this would work. I have no idea. Please help.
    What I'm wanting to do is be able to turn off my car and keep the computer on until I shutdown the computer. As the computer shuts down it would turn the inverter off.
    Any ideas?
    Thanx!!!
    Variable Bitrate nsmoller's Avatar
    Dec 2004
    NY
    you may need to directly juice the inverter from the battery
    [4Runna]
    next - wifi
    Newbie SVTRanger's Avatar
    Mar 2005
    Oak Harbor, Wa
    I ran a dedicated line from the battery and installed a relay, then used the acc. wire and 12v from Power supply, with diodes to activate the relay. Hope that helps, I can draw it For you if you want.
    Install { 50% } Complete for now.
    But stable and running happily
    Mar 2005
    Waynesville, Ohio
    Thanx SVTRanger, that sounds alot easer and alot less wire to run.
    Maximum Bitrate KyleYankan's Avatar
    Mar 2005
    I've been working on this schematic. It basically turns on power to an inverter, whenever the ignition is on.
    However, I realized that, my pc takes a moment to hibernate. If I just have it cut power when I turn the key off, that's no good. So I did this. A second relay, that keeps power going, as long as the PC is on (parallel port pin 1 I chose). However, this would keep the PC on forever. I needed a magical way to hit the power button. So I asked for help and got a smal lschematic that turns a relay's actions into a momentary button push. So, as you turn the ignition off, the power button is "pushed". the only thing this circuit doesnt do is cut power after a minute, such as if your PC freezes on shutdown. I don't know that much about timers yets.
    Mar 2005
    woops. Forgot to attach the schematic
  1. Setting up a swtich to turn off inverter when computer turns off
    By hd54321 in forum General Hardware Discussion
    Last Post: 11-29-2004, 03:36 PM
  2. Problems with Xantrex inverter...
    By RoyN in forum Power Supplies
    Last Post: 11-16-2004, 07:26 PM
  3. Best way to wire up inverter?
    By aphesis in forum Power Supplies
    Last Post: 11-25-2003, 04:11 AM
  4. I think I've been very lucky with my inverter
    By Skraggy_uk in forum Power Supplies
    Last Post: 04-16-2003, 02:30 AM
  5. I feel like a real idiot because I cant get my inverter to work
    By gilly101 in forum General MP3Car Discussion
    Last Post: 01-31-2001, 05:44 AM
