Results 1 to 8 of 8
Thread: MP3Car Store Controller
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    http://www.mp3car.com/store/product_...6af5a15a481e5d
    Is anyone using this? Is there any reason it couldn't be used as a controller to an inverter - turning on/off an inverter and thus the PC PSU power?
    Fabricator
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    does your inverter turn on and off like a computer?
    'cause mine has a toggle switch....and from what I read this just sends a pulse to the power button.
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    Total spent on wedding so far: $3885.79
    Thanks to everyone for your support.
    I'M DEBT FREE!!
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    you could still use that though, just make it shutdown the computer via the softbutton, and just use a 40A auto relay to control the inverter. so when it turns off the power it turns off the 40A relay.
    肚子笑痛了
    S60 Install
    Oct 2003
    WI
    If you read the quick overview here, it states that in addition to switching on the PC it turns on a 12V circuit and is rated for 20 amps. Sounds ideal for inverter applications.
    Fabricator
    Oct 2003
    WI
    Quote Originally Posted by jcdillin
    You beat me to the submit post button. I have a SFF Optiplex GX-150 with only a 150 Watt PSU I was hoping to skip the relay and safely assume it'll never draw 20 amps.
    Fabricator
    May 2003
    Miami, FL
    ehh, even though mine never went near 20 amps, the sparking from everytime the relay contacted took out my first 20A relay then I switched to 40A did not see another problem
    mine was a 100watt PSU with a 300watt APC inverter
    肚子笑痛了
    S60 Install
    Oct 2003
    WI
    Well I'm trying to make this one a budget <$500 system, and hoping to omit the external relay altogether since that controller 12V turn-on circuit alone is rated for 20 amps.
    Fabricator
    May 2003
    Miami, FL
    can't hurt to try it
    肚子笑痛了
    S60 Install
  1. How long does the mp3car store take to ship?
    By Daven in forum General Hardware Discussion
    Last Post: 03-15-2005, 01:32 PM
  2. MP3Car Store Exit
    By Rundell in forum Mp3car Forum Suggestions/Comments
    Last Post: 12-07-2004, 08:12 PM
  3. Australia MP3CAR Store
    By Fox_Mulder in forum General MP3Car Discussion
    Last Post: 11-09-2004, 10:29 AM
  4. mp3car store to australia
    By dogah in forum Off Topic
    Last Post: 09-13-2004, 09:05 PM
  5. mp3car store question
    By Luderboy in forum Newbie
    Last Post: 09-01-2004, 11:52 PM
