Hello i have the same problem to did you get it??? hellp me please.Thanks
Hello
I have bought this...
http://www.mini-box.com/s.nl/sc.8/ca...it.A/id.300/.f
But then, I was so stupid to connect it wrong, so the small, grey component started to smoke.
see picture here
http://www.logicsupply.com/images/po...-120-M_big.jpg
Is well hidden by the white and black cord in the top left corner.
I think it is some sort of a coil...
I truely believe, that is the only component that is trashed....
The small grey component (coil), have an "ID" on it.
1R8
TMP T
Does anyone know if is possible to change this component ?
Please do not hook up the PW-200 backwards.
The little gray part you smoked is a choke inductor, hard to find. If you are not concerned about noise injecting back into your DC system, simply bypass it with a solder bump.
-Andrei
Originally Posted by camolas
Hello and thanks for the hellp i did do that and the pw-200-m but i dosent have power now to start the pc the green lead on the main board when pushed the satart boton starts blincking!!!Originally Posted by andrewb
The PW-200 seems to be damaged, nothing you can do in this case, sorry.
-Andrei
Ok thanks
