Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 48
Thread: My idea for a Laptop Switch for my MKIV Jetta. Can this work?!?
  1. #21
    Raw Wave BoyNextDoor's Avatar
    Aug 2004
    Walden, NY
    i see you got the $499 laptop from BestBuy. They screwed me with $150 stating it wasn't walid. darn... Good luck on your mod though...
  2. #22
    Low Bitrate Man Ace's Avatar
    Mar 2005
    Seattle
    GOD DAMNIT... I ****ED IT UP.. MY LAPTOP IS DONE...
    I have a ****ty *** solder gun and tried soldering the two wires that turned on the laptop and ****ed it all up.
    My switch is done with and so is my carputer now. damn it.
    look at this hack job.
    damn it im hella depressed. My solder gun just spread out the solder everywhere. I was toying with it for the last 4 hours and then my solder just spread over the whole board. i tried to hook it up to the laptop and then the ribbon connecting the two started smoking. Obviously not a good sign.
    there was a huge lump of solder on the board so i decided to file it down to give me a clean slate with no over build solder. thats why that part is smooth. I tried looking for a replacement switch board but of course no luck. at this point I don't know what else to do.
  3. #23
    Mar 2005
    Seattle
    oh the good lord... you are good to me...
    It is 12:45 am and I have to wake up at 6 for work tomorrow. I decided to give the laptop one more start up try before hitting bed. I connected the filed down power board. No smoke, that is a good thing. I grab my jumper wire and connected the two points that i had been trying to solder.
    AND WAH-LA!
  4. #24
    Low Bitrate studly_steve007's Avatar
    Mar 2005
    Barnsley / UK
    Quote Originally Posted by Scouse Monkey
    See if you have Wakw on Lan in your bios, you amy be able to use that instead.
    I'm in a similar place, trying to get my laptop to boot automatically but I've got Wake on LAN support, is there any chance you can point me in the direction of wot to do next to get Wake On LAN into a switch??
  5. #25
    Constant Bitrate soundoff's Avatar
    Jul 2004
    AUSTRALIA
    man what the hell did you do to that PCB!!
    if i was you i would be practicing your soldering on some less expensive junk boards before your next attempt!
  6. #26
    Mar 2004
    Belgium
    Man Ace,
    I have the Euro switch in my Euro Touareg. If I want to swicth on my front or rear fogs, at least the parking lights have to be on as well. So in Position 0 (as in your picture), without the parking lights on, you won't be able to pull the Euro switch, and boot your laptop.
  7. #27
    Mar 2005
    See I told you it could be done Ace! Your soldering skills leave something to be desired however. I am sorry that I recommended you solder, but I am glad that it worked out for you! As far as wake on Lan goes Soundoff it normally requires a special packet to make that happen, and I don't know how you are going to send an ethernet packet from the front of your car to the back. I couldn't figure that crap out, and so I went with the hacked power button.
  8. #28
    Mar 2005
    Seattle
    Quote Originally Posted by mwh350
    I am a newb at best with soldering. I have soldered before just not that small of connections and it didn't help my solder iron was huge. Damn it.
    Just a quick update. After I booted up in windows and took that picture I spent another 3 hours trying to solder the wires to the connection points. I resoldered at least 7 different times. Each time the results were different. Either the laptop wouldn't turn on or it would boot up as soon as I put the ribbon back onto the mobo.
    I think i have screwed with the switch board too much. I have soldered and filed it down several times in an attempt to get it to work. I have found that when i use my jumper wire to find where the points are, they change randomly. As soon as I find a spot where it starts from, I solder a wire to it and the laptop won't boot on my test run. Basically at this point, my laptop is without a switch basically. Either I need some real help from someone who knows what they are doing, or I need to find a replacement switch board. I have been looking everywhere.
  9. #29
    Mar 2005
    Seattle
    Quote Originally Posted by jonee
    Man Ace,
    I understand that it won't turn on in Position 0. That was just a sample pic of what it looks like. My idea was to turn it to rear fogs for a second then off. Since then, I have been recommended to put a relay between the euroswitch and laptop to start it efficiently.
  10. #30
    Mar 2005
    Seattle
    Quote Originally Posted by BoyNextDoor
    Yea, I got this laptop the day after thanksgiving for $499 without needing any rebates. I think they ran a similar promotion with rebates sometime lately.
    I have only used this laptop for a total of 2-3 hours probably. That's why it was the best canidate for a carputer.
  1. Remote laptop startup
    By ambush in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 11-24-2008, 03:28 AM
  2. Laptop vs desktop
    By wei2cool in forum General Hardware Discussion
    Last Post: 03-17-2005, 06:25 PM
  3. laptop power cotrol. an idea!
    By hotponyshoes in forum General Hardware Discussion
    Last Post: 11-23-2004, 04:18 PM
  4. Laptop remote on/off issue -- SOLVED: s2000 carputer
    By skybolt in forum General Hardware Discussion
    Last Post: 09-20-2004, 11:52 PM
  5. Help TV Out wont work on laptop
    By adrian_uk17 in forum LCD/Display
    Last Post: 05-27-2003, 01:33 PM
