Originally Posted by
mwh350
If you put just a tiny bit of solder on the tip of the iron it will keep the iron from melting away. I mean a tiny bit. What I do is put a bit of solder on the tip, and then wipe the tip with a wet sponge this is fairly standard procedure. With a little solder on the tip the heat will transfer to what you are soldering on much better because it makes a better connection. For really small spots like what you are working on I "wet the tip" with solder like i described and wipe it off. Then I touch the soldering iron to the board where I want to connect my wire we are trying to heat the board because that is where you want the solder to stick. Next add a small dab of solder to the board (don't even wory about the wire just yet). As soon as that small dab of solder goes liquid and pools to the board pull the iron away, and let this small lump of solder cool. Now grab the wire in one hand and the iron in the other. Touch the lump of solder until it goes liquid again, and push the wire in the small lump. Pull the iron away, and you have it. If this is an unneccary lesson in Soldering you can just give me a shutup newbie, and I will go away. I figure that too much information is better than too little. GOOD LUCK.
