Results 1 to 5 of 5
Thread: Will an OPUS 150W fit in a standard ATX Case?
    Maximum Bitrate hd54321's Avatar
    Jun 2004
    Los Angeles
    Simple yes or no would do here. I've done my requisite research, some help would be appreciated.
    Would an OPUS 150W fit in the standard atx chassis PSU slot? Thanks!
    -HD
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    Yes, It should do. It is about 2/3 the size of a standard size ATX psu. Not sure if the mounting holes for the opus will be in the same spot as an ATX supply tho.
    Jun 2004
    Los Angeles
    Quote Originally Posted by meddler
    That's what I meant - will the mounting holes match up...
    Raw Wave EsKALad's Avatar
    Jan 2005
    Chicago, IL
    even if they dont theres always a way to make it fit!
    Variable Bitrate The Grinch's Avatar
    Jun 2004
    Toronto, Canada
    ATX power supplies mount via four screws on the rear pannel of the case. There are no other screws or brackets other than those four I mentioned. While the OPUS may fit in the gap, you might have to fabricate some kind of bracket to mount and secure it properly.
    I think the easiest thing to do is just email OPUS and ask. They are pretty quick to reply during business hours.
    Carputer progress meter: [-----|]
    Carputer gadget meter: [--|---]
  1. Opus 150w Mini ATX 6 pin mobo power ??????
    By Impalaman in forum Power Supplies
    Last Post: 02-04-2005, 11:54 AM
  2. Replies: 23
    Last Post: 12-14-2004, 12:02 PM
  3. Will Opus 150w shuttlepc edition fit in a Morex Cubid 3688?
    By harrisonpowers in forum General Hardware Discussion
    Last Post: 11-25-2004, 08:41 PM
  4. Best case for 90w Opus.
    By Nico3k in forum General Hardware Discussion
    Last Post: 11-24-2004, 10:33 PM
  5. Micro atx case for "in car" use...
    By paperinics in forum Fabrication
    Last Post: 10-28-2004, 06:57 PM
