Results 1 to 5 of 5
Thread: Finally up and running
    Constant Bitrate Heckle0's Avatar
    Sep 2003
    Colorado Springs
    But I have a question.....
    First though much thanks to everyone on this site for all the info posted here.
    Without you I could not have gotten this far.
    First off....my pc is up and running.
    MII10000 and a M1ATX.
    Here's the question.
    With the M1ATX should I be able to turn on the pc while the car is off?
    I think I may have the wires connected incorrectly.
    Another Novice?
    Progress so far <-------*-> 88%
    Kenwood MPV5025 with Aux
    Via MII10000
    512MB Ram
    LG Slim DVD\CDRW
    Xenarc 700TS
    M1ATX
    Pharos GPS
    SYBA USB2.0 4-port Hub
    Bufalo 54Mbs Wirelessb/g PCMCIA card
    Newbie messypoopypants's Avatar
    Mar 2005
    Montclair, NJ
    Wish I could help, but seeing as though there has not been a response, I'll give a bump.
    I'm going to cut your balls off so you don't infect the rest of the world!!!
    Illinois
    I dont have that power supply, but the wire I would check is the wire that tells the unit to turn the computer on. Im assuming it has 3 wires going into it. Ground, Power, Accessory. The accessory wire tells it when to turn the computer on. And the accessory wire usually only has power when your car is turned on. What I did to remedy this and have the ability to run the computer when the car is off, is I wired a constant 12volt line into my accessory wire and put a switch on it.
    This way when i flip the swtich, regardless if the car is on or not, the power unit will see the 12volts on the accessory wire and begin to feed the computer power.
    Sep 2003
    Colorado Springs
    Thanks for the assistance guys. Battery hasn't died yet.
    Sounds great and plays great. I will post pics soon.
    Another Novice?
    Via MII10000
    512MB Ram
    LG Slim DVD\CDRW
    Xenarc 700TS
    M1ATX
    Pharos GPS
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    What nappyjim said...I think. I'm hypnotized by your avatar so I can't think straight.
    Want to:
  1. Heads Up Display with LCD
    By claylong in forum LCD/Display
    Last Post: 10-07-2003, 10:02 PM
  2. MN Meet Pics...(Large Pics!)
    By freestyler in forum General MP3Car Discussion
    Last Post: 10-11-2002, 05:28 PM
  3. Power Hook Up
    By Harvester in forum General Hardware Discussion
    Last Post: 04-24-2000, 06:27 AM
