Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: itps problem
    Mar 2005
    Sportsvan
    itps problem
    so i have an itips, just for switching on/off the mobo, my 250w pwsp. gets 12 v unswitched, together with the itps, both on the same gnd, the itps gets acc alone. but my problem is that itps doesent turn on the mobo, i can turn it on my self.
    if i messure the voltage over itps the unswitched volts is 12,4 and acc 14,4,
    but nothing happens, if i take the itps inside, and try with 13-14 volts by a power regulator, it can power up my office pc?
    strange, im a bit ****ed, please help :-)
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    So you're using the ITPS only for signaling the mobo to turn on, right?
    The way you described it, the ITPS is getting ONLY switched ACC? Or you have BOTH 12v PLUS switched ACC going to the ITPS?
    Want to:
    FLAC shakes's Avatar
    Oct 2003
    Atlanta GA
    you need both a constant power line and acc going to the itps (as bugbyte mentioned) ...
    also hook up a continuity testor to the ACPI pins on the ITPS ... then start the car ... if all is working well you should hear a short beep a few seconds after turning on the car. THen turn it off ... again, you should get another short beep.
    Do that just to verify the ITPS is acting as it should. then go from there.
    My JeepPC Install
    "there are no stupid questions, just stupid people."
    "it's been agreed the whole world stinks so no one's taking showers anymore"
    Mar 2005
    Sportsvan
    itps
    i have both acc and unswitched power to the itps, and its only functions is as a startup/shutdown ctrl...
    it can power up a mobo, i did that inside.... i have rund the wiring to itps from the headunit
    and the wires to the powersupply from the battery...!
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Try reversing the lead to the mobo on your car pc. This happened to me and reversing the connection coming from the ITPS to the mobo header worked.
    Want to:
    Oct 2003
    Atlanta GA
    and I'm assuming when the car's running you are getting voltage out on the ITPS? (I realize it doesn't go anywhere, but it tells you the unit is on)
    I'd still check continuity on the ACPI pins. I've had one ITPS refuse to turn on a mobo (bad PIC)
    My JeepPC Install
    Oct 2003
    Atlanta GA
    Quote Originally Posted by Bugbyte
    Are some mobo's sensative to that?
    very interesting.
    My JeepPC Install
    Mar 2005
    Sportsvan
    i have try reversing the pins, and i can power up my home pc , if ill try it inside, so im thinking is there another way i can power the system bu the itps, but ill think i have done everything right
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Quote Originally Posted by shakes
    very interesting.
    Mine was with my Carnetix. Worked one way, not the other. Go figure.
    Want to:
    Mar 2005
    Sportsvan
    hmmm the strange thing is, that it works inside, with a power regulator
  1. PW-120M, ITPS Problems
    By arise360 in forum Power Supplies
    Last Post: 12-09-2004, 12:42 PM
  2. ITPS Timing Problem
    By Entcee in forum Power Supplies
    Last Post: 10-26-2004, 05:30 PM
  3. Changing my position o the ITPS
    By adamis in forum Power Supplies
    Last Post: 04-24-2004, 07:13 AM
  4. ITPS and Voltage drop issues
    By Wiredwrx in forum Power Supplies
    Last Post: 04-20-2004, 06:09 AM
  5. power on problem ??? help please anyone
    By Pingo1969 in forum Power Supplies
    Last Post: 04-07-2004, 07:47 AM
