I just mounted the Opus with the distance the wire would allow.
I would just just cable wire in half and splice in some wire to give you the length you require?
Has anyone run into the problem of the power switch cable being too short (the green/white cable that runs from your Opus PS to your motherboard power pins)? I tried removing the wire from the pins in the white connector, and it's just impossible to connect a new wire since it's crimped so right.
I am now looking at using a CD-rom audio cable to replace it since they are usually longer, but I was surprised to find out how short they are.
